Great Prices on TEIN Hood Damper at TunerMarket
Tunermarket lists great prices on tein Hood Dampers! Click on links below for pricing.
Tein Hood Damper
94-01 Integra
http://www.tunermarket.com/Sea...r=ht2
RSX
96-00 Civic
S2000
Mazda 6
Miata
3rd gen RX-7
350Z
Scion xB
WRX
Easy-to-Install!
HOOD DAMPER is designed to be installed without any modification to the vehicle, so that many users can install by themselves. All needed is some simple tools!
'Loosen bolts. Put HOOD DAMPER in place. Tighten bolts.' That's basically all there is to it. Even a person who has never worked on vehicle can install HOOD DAMPER easily and quickly without any hassle.
Lightweight & Compact
HOOD DAMPER is designed to be lightweight and compact, so that it does not get in the way of any works around the engine bay. As the main body of the damper only weights 200g and the extension that adjust the full-open angle of the hood is made of Aluminum, the product is amazingly lightweight even with all parts/components attached.
Opening-Heavy-Hood Made Easy!
Hoods are usually made of steel. The bigger the vehicle is, the heavier the hood is. Opening and closing the hood can be extremely troublesome, especially in a case of emergency for people who does not do work on his/her vehicle on regular basis. Many people want to open / close the hood much more lightly and easily. To meet such demands, TEIN has developed HOOD DAMPER.
Highly Durable!
HOOD DAMPER has met our strict quality standard and passed one hundred thousand times of Expansion & Contraction Test. In consideration of severe use conditions, as it is placed inside the engine bay, surfaces of each and every part are specially treated for corrosion-proof to stand 5 years of use.
To compare prices on tons of other great parts click on the link below!
Tein Hood Damper
94-01 Integra
RSX
96-00 Civic
S2000
Mazda 6
Miata
3rd gen RX-7
350Z
Scion xB
WRX
Easy-to-Install!
Highly Durable!
SupaMonkey
Feb 17, 2011 10:31 AM
Ventolin
Other Make Vehicles
16
Jul 17, 2009 10:04 PM
