STUBBORN A55 HEADLIGHTS, HELPPP!!
so i saw a topic on diy ctr housing lights, and skool is done, so ihave the whole day ahead of me..i go out to my car, and attempted to take out my lights and do the whole procedure..i unscrew the 2 top screws that hold the lights in place, and tried pulling it out gently, but its stuck...i check under the car, over the car, and i cant seem to pin point the problem..it seems that at the edge of light that is closer to the fender, the narrower part of it, wont budge..is there some sort of secret screw !!! geez..if anyone knows anything, ur help would be greatly appreciated, thanks!!!
There are 4 screws that hold the headlight! Two on the top, one on the side by the fender, and one on the other oppisite side. But if you have never taken them off before you need to take off an bracket too. There is an bracket infront of the headlight that hold it in place too, which is behind the bumper. So you nd to take off ur bumper to get to that bracket. Two screws hold it place, and one you take it off then your good to go!
wakaranai
Oct 8, 2007 02:03 PM
