AT to MT swap. What to do about key cylinder lock override?
Old May 6, 2005 | 09:31 AM
Jonathan_ED3's Avatar
Default AT to MT swap. What to do about key cylinder lock override?
after completing an auto to manual swap, I realized that you cannot take the key out of the ignition until you disconnect the battery.
I figure this is because on the auto- manual swap you essentially jump the harness to make the car think it's in 'drive' all the time; I guess on an auto you cannot take the key out with the gear in 'drive'.
How do you get around this?
What harness do I have to jump/modify? I searched through the info i previously gathered and I don't see this problem addressed.
TIA.
Old May 6, 2005 | 09:36 AM
vegaskurt's Avatar
Default Re: AT to MT swap. What to do about key cylinder lock override? (Jonathan_ED3)
I just did this, write up is at http://www.4gcivic.net
Look at the large multi wire connector that was near the auto shifter. There should be a pin missing. Hold the clip so that the missing pin is at the lower right. The pin directly above it has to be shorted with the pin to the left of it. (hope that makes sense). If you short it with a paper clip (to test) you will see the park light come on. Then just clip the wire and solder them together.
Old May 6, 2005 | 09:55 AM
Well I've got those jumped. The car starts just fine...but it just won't let me get the key out.
It doesn't make sense to me.
Old May 6, 2005 | 10:05 AM
vegaskurt's Avatar
Default Re: (Jonathan_ED3)
Is the park light on?
The only wires you need to jump are the ones I described (which control the park light and key release) and the two thick wires on the other clip (starter kill).
DA9Sleeper
Aug 10, 2010 10:44 AM
Dukie432
Apr 18, 2009 09:48 AM
tyler100
Jun 5, 2008 07:19 PM
joshb_
20
Mar 15, 2007 05:41 AM
pr0jektdc2
May 9, 2006 07:18 PM
