Suspension & Brakes Theory, alignment, spring rates....
How much camber adjustment would be needed?
Old May 6, 2005 | 08:32 AM
AZMyst's Avatar
Default How much camber adjustment would be needed?
Going with H&R Sport Spings and Koni Yellows on the 95 VX. Don't need anything more radical than that b/c this a street car that will only see a few track days a year, with a little drag racing thrown in for good measure.
My main question is, how much adjustment (best guess) would be needed to make sure the negative camber can be adjusted out? I see kits that state +1-+2, or -0.75-+1.5. I definitely want a camber kit, but which one should a get to make sure I get enough range out of it? Thanks!!
Old May 6, 2005 | 09:06 AM
AutoXer's Avatar
Default Re: How much camber adjustment would be needed? (AZMyst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZMyst &raquo;</TD></TR><TR><TD CLASS="quote"> I definitely want a camber kit, but which one should a get to make sure I get enough range out of it? Thanks!!</TD></TR></TABLE>
You don't need one for that setup. Get an alignment, and you'll be fine.
Old May 6, 2005 | 09:12 AM
AZMyst's Avatar
Default Re: How much camber adjustment would be needed? (AutoXer)
Thanks for the info! Save me a couple hundred bucks!
Old May 6, 2005 | 09:14 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZMyst &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info! Save me a couple hundred bucks!</TD></TR></TABLE>
No prob, but make sure you get an alignment right away, and have them set the toe to 0.
Old May 6, 2005 | 10:06 AM
AZMyst's Avatar
Thats goes without saying. I'm goin to have it installed at the same shop that does my alingments anyway.
Black_ex
Honda Civic (2006 - 2015)
Jun 24, 2008 07:34 PM
Sassafrass
Suspension & Brakes
May 13, 2008 08:16 PM
LoseRPunKx182
Suspension & Brakes
Aug 6, 2005 10:57 AM
full Circling
Jan 5, 2005 07:32 AM
xstalkrx
Apr 24, 2003 05:37 AM
