1994 EX four wheel disc brakes Stock, Basically a 1994 SI coupe.
Old May 6, 2005 | 08:18 AM
ROOROWNS's Avatar
Default 1994 EX four wheel disc brakes Stock, Basically a 1994 SI coupe.
HEy
my girl just picked p a 1994 EX with 92k on it, new hoood, front bumper, and fenders. New paint, Sunroof, ABS ( i believe reason for 4 wheel discs?)
So now that the ABS lights on and the ABS in not functioning, I would like to remove it. I know i need a new proportioning valve or combo valve whatver it is. I need new hard brake lines but what else. can i leave the Stock ABS harness in there? Also can i bolt a bigger caliper to the rear or am i stuck with those tiny little calipers. ( not like i really care i am just psyched that it has four wheel dics).
So basically she has a 1994 SI coupe, doesn't the Hatchback SI just come with four wheels dics and a sunroof and a d16z6. Those are the only things making it an SI right?
Sean
Old May 6, 2005 | 09:16 AM
TallAssFilipino's Avatar
Default Re: 1994 EX four wheel disc brakes Stock, Basically a 1994 SI coupe. (EG_Black_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_Black_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">HEy
Sean</TD></TR></TABLE>
Don't bother removing the entire ABS setup. There's a lot of work to do. You can just disable the modulator. I don't know the correct method of doing it, but it was done to my 94 Si w/ABS.
Old May 6, 2005 | 10:11 AM
longbeachpurplecivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_Black_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">So basically she has a 1994 SI coupe, doesn't the Hatchback SI just come with four wheels dics and a sunroof and a d16z6. Those are the only things making it an SI right?
im not sure wt your asking but here. 94-95 ex have abs so it has rear disc. 92-93 doesnt. 94-95 sedan ex also comes with it. 92-95 hb si is sport so it got d16z6 and sroof
VTECwalka
15
Dec 15, 2013 10:58 AM
CunninLynguist
24
Nov 22, 2006 11:50 AM
SpoonFedHatch
Dec 10, 2003 09:48 AM
csprague
May 25, 2003 02:29 PM
GetawayInMoscow
10
Mar 28, 2003 01:49 PM
