zc problems in 89 hatch
do you have an obd-1 conversion harness?
i bet your problem is the distributor, throw an obd-0 dizzy on there and she'll fire up
your dizzy and ecu have to be the same obd basically
I've never heard of someone wiring an OBD1 dizzy as OBD0.
weird...
And if they said the ecu was fine and you did all the wiring right, then the obviously dizzy isn't fine
weird...And if they said the ecu was fine and you did all the wiring right, then the obviously dizzy isn't fine
if its a dohc zc check your cyl position sensor wires they might be crossed
if not check the 2 white wires on the dizzy and check your timing belt it might have skipped a tooth
theidealone
Apr 14, 2008 06:21 PM
97grnrs
Dec 10, 2006 04:14 PM
crxzcracer
Mar 2, 2005 03:39 PM
