VTEC and idle problems.. help needed
Old May 5, 2005 | 09:50 PM
mr_vtec's Avatar
Default VTEC and idle problems.. help needed
OK, here are my problems (car is 92 hatch with b16a)
On cold start my car likes to idle at about 2500 up to 3000 rpm. After searching other posts, it seems it could be the fast idle sensor but i'm not to sure.? Secondly, VTEC doesn't want to engage anymore. I changed the oil about 2 weeks ago, along with some new spark plugs. After changing the oil, i let the car warm up and went for a drive..... NO VTEC! i took the car home after that, parked it in the drive way over night and when i drove it the next morning VTEC was working for a few hours without any trouble. I turned the car off, got lunch etc and after that.... NO VTEC AGAIN!
Since then VTEC hasn't worked again.
I also noticed a leak in the headers, i'm wondering if this could be upsetting a sensor?
I've been told so many things as to what it could be, but a little confused as to where i should start? I've also been told that a new computer will solve all my problems?
Any info or advice would be appreciated
cheers
Lloyd
Old May 5, 2005 | 10:19 PM
Cuong-nutz's Avatar
Default Re: VTEC and idle problems.. help needed (mr_vtec)
is th ECU throwing any codes? CEL light on? Check the connections from the VTEC solenoid all the way to the ecu. VTEC engagement is dependent on oil level and pressure as well as proper connections to th ecu.
Replace the exhaust gasket on your leaky header.
Old May 5, 2005 | 10:35 PM
siflyby's Avatar
idle screw setting??? Throttle cable setting???
Old May 6, 2005 | 01:33 AM
mr_vtec's Avatar
Default Re: VTEC and idle problems.. help needed (siflyby)
checked idle screw and throttle cable and all seem to be in order...
Checked for codes and the engine light just stayed on!?
am i doing something wrong, or does this mean somehting?
Bj Le Det
Jan 6, 2017 12:06 AM
uhhhh4doors
Mar 2, 2010 09:58 AM
iphatcrxi
Sep 13, 2006 10:03 AM
Mr_CRX
Sep 29, 2004 12:01 PM
