Yokohama Parada Spec-2 VS ES 100
Old May 5, 2005 | 09:21 PM
RNPoo7's Avatar
Default Yokohama Parada Spec-2 VS ES 100
I noticed that the spec II has a longer threadwear. Anyone tried the spec IIs, trying to see which one I should buy.
Need them for my daily driver turbo intega.
TIA
Old May 6, 2005 | 03:39 AM
Neo79Si's Avatar
Default Re: Yokohama Parada Spec-2 VS ES 100 (RNPoo7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 &raquo;</TD></TR><TR><TD CLASS="quote">I noticed that the spec II has a longer threadwear. Anyone tried the spec IIs, trying to see which one I should buy.
TIA</TD></TR></TABLE>
The difference in treadwear ratings between the Parada Spec-2 & the ES100 (300 VS. 280, respectively) is insignificant. I would avoid drawing any conclusions about which tire will wear longer when the numbers are that close.
I replied to another question about UTQG ratings in another post and went into a fair amount of detail if you'd like to check that out...
https://honda-tech.com/zerothread?id=1235189
Basically, the treadwear number is assigned relative to a 195/75R14 Uniroyal Tiger Paw all season tire. That tire is given a rating of 100, and everything else is based off of that as part of DOT required testing. So to say that the parada's and ES100's are significantly different is a stretch.
Let me know if I answered your question!
Matt
Old May 6, 2005 | 07:05 AM
nsxtasy's Avatar
H-T Order of Merit
Need them for my daily driver turbo intega.</TD></TR></TABLE>
If you're using the stock 15" wheels, you'll have to get the ES100. The Parada Spec 2 doesn't come in any 16" sizes.
I'm using the ES100 on my GS-R. Performance is fine, both wet and dry (they ROCK in the rain), and based on the tread depth so far, it looks like they might last 40,000 miles.
However, if you're looking for something whose performance is up to meeting the challenges of the turbo, you might want to consider spending more money for a top of the line tire (e.g. Bridgestone S-03, Kumho MX, etc), rather than one of these "budget performance" tires.
Old May 6, 2005 | 10:06 AM
Dave421's Avatar
the es100s tend to do better after they heat up as well. I've not had them but a friend ran the spec 2s on his del sol. They'd do pretty good for a run or two (auto-x) but once they heated up, they got greasy. People will run the ES100s during HPDEs and track events without them getting greasy so....
Old May 6, 2005 | 10:46 AM
RNPoo7's Avatar
According to tires.com both come in 15 and 16".
Neo, thanks for the info. Very helpful
Old May 6, 2005 | 11:02 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (RNPoo7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 &raquo;</TD></TR><TR><TD CLASS="quote">According to tires.com both come in 15 and 16".</TD></TR></TABLE>
I don't think so; you might want to check again. I just checked tires.com and they only list Parada Spec 2 sizes for 16" and larger wheels. That's also true of the Yokohama website and Tire Rack website; both those websites only list Parada Spec 2 sizes for 16" and larger wheels.
Old May 6, 2005 | 11:05 AM
RNPoo7's Avatar
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
ok oh, yah i goofed up the search. I need 16" anyway, so it's all good.
I think i'm gonna go with the ES100s
Ross
Honda Motorcycles
31
Jul 8, 2006 05:34 PM
Integra21
Jul 19, 2005 01:42 PM
slow91crx
Jun 25, 2005 07:10 AM
SuicideSlide
Jan 13, 2005 06:52 PM
nickgsi
Acura NSX
May 8, 2004 02:46 PM
