pulse in brake pedal, escpecially on highway - anyt thoughts?
Hey guys,
Im getting a pulse feedback in the pedal when i apply brakes. on the highway the steering sometimes pulses with it. any thoughts? any additional information needed?
thanks in advance
thanks in advance
try slowing down using e-brake only if pulse is there it is coming from rear drums if no pulse and only happens when you brake frt rotors warped just like jonathan said ,,resurface or replace depending on thickness
Also check the tierod ends. Worn tierod ends combined with warped rottors = BIG SHAKE also associated with sudden darting left or right when first applying the brakes at speed.
Vagitarian
23
May 8, 2013 09:38 AM
leekor12
Apr 19, 2007 07:05 PM
