Stalling problems
Old May 5, 2005 | 08:30 PM
djshakes's Avatar
Default Stalling problems
I have a 90 integra GS. It has about 168,000 miles on it. I just changed the alternator about a month ago. The car died on me twice in the middle of driving the other day. I put a new battery in it and tested the alternator. All is fine. Then it died on me again. It happened both times when I was coasting with the clutch in. I pulled the plugs and check them. They are fine. What do you think it could be? Fuel filter. I tried pulling it off but man are the hoses connected tightly. I am a strong guy and couldn't break them loose. I drove it a short distance tonight with no problems. What do you think it could be?
Old May 5, 2005 | 08:56 PM
Soku1kcivic's Avatar
Default Re: Stalling problems (djshakes)
fuel injector, dizzy, could be ur terminals are loose, thats all i can think can u be more specific
Old May 5, 2005 | 09:02 PM
djshakes's Avatar
Default Re: Stalling problems (Soku1kcivic)
Bat terminals are tight and clean. Battery is new. Alternator is new. Why would the car shut off when driving? I pull over and crank the key. It starts again. The first time is started right away. Second time took a while. I had to crank it quite a few times. I then changed the battery and tested the alternator. All was fine. I drove it about another 15-20 miles and when I was coasting the car died again. Started up right away. I drove it another ten miles and everything seemed fine. I just don't want this to continue and be stranded some where. I am narrowing it down to dirty injectors, bad fuel filter or pump. What do you think?
Old May 6, 2005 | 06:36 AM
jamey220's Avatar
check ur tps sensor
Old May 6, 2005 | 09:09 AM
djshakes's Avatar
Default Re: Stalling problems (jamey220)
You might as well be speaking a foriegn language. Where is it and what am I checking it for?
Johnoolo
Sep 16, 2013 05:15 AM
philkehn
13
Sep 7, 2006 03:58 PM
Tru
Apr 11, 2005 07:10 PM
