Anyone know what the theory behind using colder plugs due to change in exhaust?
Old May 5, 2005 | 07:31 PM
euG3dc2r's Avatar
Default Anyone know what the theory behind using colder plugs due to change in exhaust?
Anyone know what the theory behind this statement is?
From the j's racing website -
http://www.jsracing.co.jp/
--> products --> exhaust ---> dc2
"Use more than no.8 of the iridium plug due to better ignition efficiency"
right now, I'm assuming that j's recommend the colder plug after modification of the exhaust.... but why? Is it really better ignition efficiency or just a bad translation
Old May 5, 2005 | 07:36 PM
Bbasso's Avatar
Default Re: Anyone know what the theory behind using colder plugs due to change in exhaust? (euG3dc2r)
Your changing the way the motor/ exhuast is working, Since I have changed my exhaust to a much better flowing system I have noticed the plugs cleaner and I have been getting better MPG.
Old May 5, 2005 | 07:45 PM
Stripped Si's Avatar
Default Re: Anyone know what the theory behind using colder plugs due to change in exhaust? (Bbasso)
What plugs are you using?
Old May 5, 2005 | 07:52 PM
euG3dc2r's Avatar
Cools, what plugs are you running?
OEM is the 6E's but the site is recommending a 8E ...
Old May 6, 2005 | 01:03 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by euG3dc2r &raquo;</TD></TR><TR><TD CLASS="quote">Cools, what plugs are you running?
OEM is the 6E's but the site is recommending a 8E ... </TD></TR></TABLE>
a heat range 8 plug for just an exhaust?
&lt; uses a 7 on his turbo hatch.
I'd like to see more info on this.
Old May 6, 2005 | 01:24 AM
Bbasso's Avatar
Default Re: Anyone know what the theory behind using colder plugs due to change in exhaust? (Stripped Si)
Other then a AEM intake and header back exhaust my car is stock, Including plugs.
As for what I meant cleaner... less oil build up on a hard drive. (plugs checked immediately after drive.)
FFparamedic1986
Honda Civic (2006 - 2015)
Dec 5, 2011 02:35 AM
ryaneg
Nov 27, 2007 02:51 PM
Phatch99
Sep 8, 2005 12:39 PM
blackccoupe
Mar 31, 2004 02:50 PM
faultofhumanity
15
Sep 22, 2003 09:34 AM
