B16 Swap Front Motor Mount Problem
Old May 5, 2005 | 07:26 PM
CRX MASE's Avatar
Default B16 Swap Front Motor Mount Problem
Do you use the front motor mount that came on the b16? Because i'm having trouble getting mine to line up. Btw i'm using Hasport motor mounts.
Old May 5, 2005 | 07:34 PM
doublethink's Avatar
Default Re: B16 Swap Front Motor Mount Problem (DavilleKy)
it doesnt use the front mount.
its a 3 mount kit with stiff urathane inserts.
if you want to weld a mount for it on the front x-member or seomthing go to town, but nothings going to line up for you on that one.
Old May 5, 2005 | 07:37 PM
CRX MASE's Avatar
So i don't have to use that mount at all?
Old May 5, 2005 | 07:50 PM
slowman's Avatar
I took way too long
No front engine mount on my CRX, using Hasport mounts too.
Old May 5, 2005 | 08:32 PM
Bad89rex's Avatar
the hasport mounts use 3. 2 sides, and the rear. if you want a front mount you will need to fabricate one yourself. I am going to fabricate one for myself. with a home made xmember. lol
sloweredcivic
May 15, 2005 09:01 PM
SOHC_Brian
Aug 11, 2004 11:30 AM
SkunkCrxSi
18
Jul 23, 2004 07:34 AM
DJ_SaNdOz
Feb 10, 2003 09:10 AM
johnzm
11
Jul 30, 2002 06:15 PM
