Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Cryo treating transmissions
Old Feb 3, 2002 | 09:46 AM
MaddMatt's Avatar
Default Cryo treating transmissions
Some of my SR20 peeps are breaking transmissions when drag racing with drag radials. Does anyone know of anyone that cryo treats large object like entire transmissions? I think I've heard of engine blocks being treated, so it shouldn't be impossible.
Old Feb 3, 2002 | 10:36 AM
.RJ's Avatar
.RJ
Default Re: Cryo treating transmissions (MaddMatt)
sure you can cryo-treat 'em. Whats breaking? gears? cases? output shafts? diffs?
-Ryan
Old Feb 3, 2002 | 10:48 AM
MaddMatt's Avatar
Default Re: Cryo treating transmissions (Type-RJ)
I've never had a problem personally. For some reason, transmission cases on B13/14 (91-99 Sentra/NX2000) Nissans crack when drag radials are used. Even if solid motor mounts are used.
Matt
[Modified by MaddMatt, 11:48 AM 2/3/2002]
Old Feb 3, 2002 | 01:04 PM
.RJ's Avatar
.RJ
Sounds like maybe solid motor mounts would only increase the likelyhood that it cracks - if a solid mount is in place its transmitting force/vibration rather than absorbing it. I would think that cryo treating would definately help these cases stay together, i gather that this is a stress failure. Its not that expensive ($600 or so for an engine block, IIRC), especially if it keeps you from cracking tranny cases and/or shredding gears because of it. Where do the failures occur? I would guess radially across the bellhousing (i.e. across the case from front to back of the engine bay).
-Ryan
Old Feb 3, 2002 | 03:13 PM
MaddMatt's Avatar
That sounds right. Like I said I haven't had any problems. Oddly, it only happens when using drag radials.
I suppose one solution is they could stop drag racing the darn thing....
Old Feb 3, 2002 | 05:27 PM
.RJ's Avatar
.RJ
Yeah but its more interesting when you keep breaking stuff
Old Feb 3, 2002 | 07:04 PM
Lees Z's Avatar
New User
Call Bill DeFelice at
Fountainhead Cryogenic Processing, LLC
York, PA 717-880-5730
He does it all
Old Feb 4, 2002 | 06:48 AM
MaddMatt's Avatar
Default Re: Cryo treating transmissions (Lees Z)
Thanks Elyse!!
Old Feb 4, 2002 | 07:05 AM
r2x's Avatar
r2x
You could also drop Bowie a line. I know he sends stuff to the nascar shops in Charlotte to get dipped along with their "big" stuff. Give him a call and ask what his connection is.
nitrotiger
Jan 31, 2010 07:14 PM
94eghatchcx
Sep 6, 2007 10:38 PM
Patron
Sep 16, 2004 02:08 PM
slowdx
Jul 25, 2003 10:46 PM
crashtest Sonny
Sep 22, 2002 02:25 AM
