stud replacement?
Old May 5, 2005 | 06:14 PM
sharinelson's Avatar
Default stud replacement?
how to replace a broken stud in the front wheel?
Old May 6, 2005 | 03:58 AM
Neo79Si's Avatar
Default Re: stud replacement? (sharinelson)
I sheared one in half in the dead of winter in Ohio this year. I believe I would've had to take off the entire front hub assembly, including the huge bolt that attached it to the axle. Since it was freezing outside I took it to the dealership and had them do it for $45. Haha.
Old May 6, 2005 | 09:21 AM
King-Kong's Avatar
are you capable of changing a stud? I just changed all mine to the ARP's and I love them, I didnt even take off the hub, just grinded it down far enough so i could hammer out the old studs and put in the new one. If you need more info or some pics i can try to get you some. LMK ...
Old May 6, 2005 | 10:31 AM
aznteg's Avatar
Default Re: (turbo_CRX)
what car did u change th stud on? i tried to work my integra but the stud was too close to the hub to be hummer out and if i do get it out it would be too tight to get it in
Old May 6, 2005 | 09:31 PM
King-Kong's Avatar
did it on a 90 si civic, I had to dremel a bit of material off the hub and it fit through no probs.
my99ekcoupe
Sep 3, 2010 05:28 PM
ewoo
Feb 24, 2009 04:23 PM
cheifncomer
Nov 21, 2008 04:15 PM
n-line4
Apr 20, 2005 02:14 PM
CNSK
Nov 5, 2002 03:25 PM
