Hooking up FJO wideband. Says to tie into ecu power supply. Which wire is it?
Old May 5, 2005 | 06:07 PM
hughesl's Avatar
Default Hooking up FJO wideband. Says to tie into ecu power supply. Which wire is it?
The FJO intall guide says to hook up to the ECU power line so the wideband only gets power when the car is running. Which wire is that?
Thanks for the help
Old May 5, 2005 | 07:10 PM
drdisco69's Avatar
Default Re: Hooking up FJO wideband. Says to tie into ecu power supply. Which wire is it? (hughesl)
Try either one of the yellow/black wires.
Old Jun 1, 2005 | 05:30 AM
Used2beAb16's Avatar
Default Re: Hooking up FJO wideband. Says to tie into ecu power supply. Which wire is it? (drdisco69)
Im curious about this too. Which yellow black wires?
milanoitr
Feb 27, 2012 04:52 PM
GagnarTheUnruly
Engine Management and Tuning
Sep 1, 2011 11:34 AM
solerizr
Mar 3, 2007 07:46 PM
EF9ZC
Apr 1, 2006 07:13 PM
TurboJesse
Apr 29, 2003 01:33 PM
