rod bearing question.
Old May 5, 2005 | 05:52 PM
ALLMOTA92EG's Avatar
Default rod bearing question.
how do tell what size of rod bearings you'll need for a rebuild? its for a b18b ls motor.
Old May 5, 2005 | 10:41 PM
rjay8604's Avatar
Default Re: rod bearing question. (jdm92civichb)
Well you can either check with a micrometer and bore gauge. Or you can order a set of standard size bearings (green) and then platigauge those. If the crank is in good shape and the bearing look pretty good too, you can likely get standard size green bearing and they will probably all check into factory spec.
D.Dappa
Jul 16, 2007 01:57 PM
Thepanda
May 17, 2007 06:22 AM
tgreaves
Jan 22, 2004 05:52 PM
sir2k
Mar 5, 2003 11:33 PM
