What are normal water temps for a boosted b18c?
What do you guys mormally see your water temp at when driving on the freeway and also when in the city and it's stop and go traffic?
Also has anyone evr used Redline Water Wetter? Does it work well and would you reccommend its use?
I'm usually around 180* to 185* F with a little bit of water wetter, 70/30 water/anti-freeze mix, no AC equipment, and a Fluidyne full-sized radiator. I'm NA, not boosted tho.
Most engines will probably be around 220* F.
