zc exhaust header
Old Feb 3, 2002 | 08:52 AM
tdc's Avatar
tdc
Default zc exhaust header
i was looking at some zc swaps and found that the stock zc header will not match up to the stock exhaust.. has 2 pipes coming from it. why? did they have daul pipes to the back or what. looks like a header is the way to go with this swap or a si but if you have to buy one . mite as well go with the header. right?
Old Feb 3, 2002 | 09:30 AM
therealciviczc's Avatar
Default Re: zc exhaust header (tdc)
You can use a 92-95 Ex or Si down pipe with the ZC top piece. It hangs a little lower than it should, but I ran mine for about 1 year on a civic that is pretty damn low, and never really had problems. I got mine from the junkyard for $10.
I'd go aftermarket if you can afford something decent. Don't get a cheap (pace setter) header though. If you don't have the cash, pick up to Si bottom piece until you do.
Old Feb 3, 2002 | 09:41 AM
89civicdx's Avatar
Default Re: zc exhaust header (therealciviczc)
It will match up to the stock midpipe, you must be looking at some chopped up down pipe or somthing. The stock ZC down pipe merges into a collector that will match up to a crx/civ cat flange BUT somtimes when the motors come over from Japan those collectors are chopped off and all you have left is the 2 pipes from the downpipe.
[Modified by 89civicdx, 10:42 AM 2/3/2002]
Old Feb 3, 2002 | 11:28 AM
Hondasaurs's Avatar
Default Re: zc exhaust header (89civicdx)
I have a DC sport 4-2-1 ceramic header port matched to the ZC if you are interested. You can email me at hellspawnonline@hotmail.com
Old Feb 3, 2002 | 06:17 PM
tdc's Avatar
tdc
Default Re: zc exhaust header (ZC_CRX)
thanx for the offer but i`m in canada so it`s not worth the hassle to ship
Old Feb 3, 2002 | 06:30 PM
cottagecreep's Avatar
Ya, I ran into that problem, where the header here are a 4-1 design, and the zcs had a 4-2-1 design. You have two choices, find a 2-1 pipe to throw on there, I actually have one, it came off an SIR, (but I need it) or, get a new header, or throw your old header on there. I ended up using my old header, and just took a dremel tool to open up the ports on the old header a little more.
Old Feb 3, 2002 | 06:32 PM
91HATCH's Avatar
you can also use 96-98 ex down pipe too?
smokez187
Jun 9, 2007 01:22 AM
B18C5-EH2
11
Feb 17, 2005 04:35 PM
mateencrx91
23
Jan 23, 2004 12:10 PM
tpr
Mar 13, 2003 12:22 PM
tdc
Feb 25, 2002 04:30 PM
