Question about which valve springs to use with Jun #'s
Old Feb 3, 2002 | 08:34 AM
canuck-mx6's Avatar
Default Question about which valve springs to use with Jun #'s
Can I use ITR outers, and port flow inners with Jun 3's? I will be using crower titanim retainers. I want to be able to rev to 9k safely. I am also using CTR pistons in my GSR for 12.3:1 compression.
Will I have any clearance issues?
Old Feb 3, 2002 | 08:51 AM
JSIR's Avatar
New User
Default Re: Question about which valve springs to use with Jun #'s (canuck-mx6)
the spring retainer combo works fine with Jun3's, as for the CTR pistons and clearance that is hard to tell, you should really clay the motor and test the cams with the rocker arms locked in place. I remember JunUSA saying you can run CTR pistons with the cams as long as the cam gears are at 0,0 position or you use stock cam gears. But I wouldn't trust my motor to that kind of generalized statement, so spend the extra time and clay it.
J.
Old Feb 3, 2002 | 10:43 AM
Vtec integra's Avatar
its safe, my friend was running the same set-up and also a shaved head.
he had his cam gears set at intake 0 and exhaust+ or -1 i forgot
i have the same settings on my car
Old Feb 3, 2002 | 11:27 AM
Liquidx02's Avatar
Default Re: Question about which valve springs to use with Jun #'s (JSIR)
you will have no clearance problems. You have clearnace clarence
Old Feb 3, 2002 | 11:30 AM
alexboy's Avatar
Default Re: Question about which valve springs to use with Jun #'s (Rattlesn8ke)
I posted a response in the integ board but jun says you must use the springs and the retainers and cam gears are recommended I know a few peeps run other vavle springs with these cams though
Damn I wish i could install mine know
endlessjdmeg
Aug 12, 2007 08:24 PM
blacksihatch
Oct 18, 2005 12:21 PM
bride_japan
May 29, 2005 06:11 PM
civiksi
Jun 9, 2002 09:27 AM
canuck-mx6
Feb 3, 2002 09:20 PM
