Need Help with a 98 h22 swap into my 99 civic coupe
Old May 5, 2005 | 07:54 AM
High-Velocity916's Avatar
Default Need Help with a 98 h22 swap into my 99 civic coupe
hey guys.. i have no clue or ideas how to drop this 98 h22 in to my coupe.. dont know wat is need in this process or how it should be done.. so can anyone help?? clues??? thanx alot
Old May 5, 2005 | 09:36 AM
Cwhiteg6's Avatar
Default Re: Need Help with a 98 h22 swap into my 99 civic coupe (High-Velocity916)
you buy a swap and have no idea on how to swap it?? h22 is a very hard swap to do, i do know that when you purchase the swap you also need to purchase the hasport motor mounts for it to fit into your car and you need stronger axles because the stock ones just wont work and im pretty sure you have to cut out a piece for the shift linkage because its a cable shifter.
Old May 6, 2005 | 08:30 PM
Default Re: Need Help with a 98 h22 swap into my 99 civic coupe (civtecek9)
thanx bro..
Old May 6, 2005 | 10:04 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtecek9 &raquo;</TD></TR><TR><TD CLASS="quote">h22 is a very hard swap to do</TD></TR></TABLE>
not true, why do so many ek guys **** and **** their pants as soon as they hear 'mount kit' ? lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtecek9 &raquo;</TD></TR><TR><TD CLASS="quote">you need stronger axles</TD></TR></TABLE>
if you make power or beat on the car you break axles.. doesn't matter if it's a d15 or turbo H23. has nothing to do with the h22a.
Once you have the kit you should be fine. if you click search and search the eg+ civic/del sol section i'm sure you can find some really good info on the swap.
good luck.
High-Velocity916
May 13, 2006 06:35 AM
96TEGgSR07
14
Feb 9, 2006 09:46 AM
High-Velocity916
May 6, 2005 11:30 AM
High-Velocity916
May 5, 2005 04:43 PM
fucT
68
Feb 10, 2005 02:11 PM
