what does offset mean
Old May 4, 2005 | 02:43 PM
xoutlawz00x's Avatar
Default what does offset mean
what does offset mean?? and im looking for steelies for my type r suspension. do i look for 5x114.3
Old May 4, 2005 | 03:32 PM
SixxT9's Avatar
Default Re: what does offset mean (xoutlawz00x)
5x114.3 would be your bolt pattern (or A bolt pattern).... can't help you with offset though. Sorry.
Old May 4, 2005 | 06:32 PM
Moogen Powah's Avatar
Default Re: what does offset mean (SixxT9)
It's explained in the FAQ:https://honda-tech.com/zerothread?id=1188922
Old May 4, 2005 | 07:45 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what does offset mean (Moogen Powah)
It's also explained on the Tire Rack website, here, using this diagram:
Old May 4, 2005 | 08:30 PM
Default Re: what does offset mean (nsxtasy)
i still don't get it
Old May 5, 2005 | 05:51 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">i still don't get it</TD></TR></TABLE>
Did you try using the link in my previous post (by clicking on the word "here"), and read the entire web page on the Tire Rack website?
Old May 5, 2005 | 06:09 AM
jg's Avatar
jg
...from the link above
"The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types.
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset."
If the image above doesn't make offest clear, there's not much hope.
Old May 5, 2005 | 06:59 AM
Default Re: what does offset mean (jg)
yo thanks alot now i get it.. so what a good or safe offset?? so i don't rub
Old May 5, 2005 | 11:14 AM
SixxT9's Avatar
OEM is always a "safe" offset value. Find out what your stock offset is.
EDIT: Rather the stock offset of ITR oem rims/suspension
Old May 5, 2005 | 03:44 PM
jg's Avatar
jg
for 7" wide, 40-43mm offset should work.
pakittoo
Nov 26, 2010 01:46 PM
nexgen91
Apr 23, 2006 02:46 PM
DC_RaceR
16
Feb 7, 2006 03:48 PM
Todd00
Jun 14, 2004 10:10 AM
clean
Jul 13, 2002 07:49 PM
