Small tip for removing sound deadning: DRY ICE!!
Old May 4, 2005 | 11:38 AM
Slapshotnerd's Avatar
Default Small tip for removing sound deadning: DRY ICE!!
I'm helping prep a race car (not drag, but can be used for drag), and Dry ice worked wonders! we picked up 20 lbs from a shop we found on http://www.dryicedirectory.com (only cost us $20) and were able to get almost all of it done with that much.
We put the dry ice directly on the material, then waited around 5 minutes, and hit it with a hammer and chissle. In a matter of around 2 hours, we got 90% of the material out. It comes out in rather large chunks, as the dry ice breaks down the chemical bond in the adhesive.
Screw a heat gun and scraping, the dry ice is WAY easier to clean up too!
Old May 4, 2005 | 12:10 PM
paulzy's Avatar
welcome to 1999
Old May 4, 2005 | 03:46 PM
the jdmchop's Avatar
Default Re: (paul vang)
bro its eaier thaan that just do what i did ... wait till its about -30deggrees outside and just bang the **** offwith a hammer
Rod.'s Avatar
nice info
Old May 4, 2005 | 03:56 PM
Trooper's Avatar
Default Re: (redturbocivic)
For the areas that are hard to reach, make a Dry ice slushie with some rubbing alchahol. That will work wondres by the firewall.
Old May 4, 2005 | 04:15 PM
Karterguy13's Avatar
Default Re: (jdmchop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmchop &raquo;</TD></TR><TR><TD CLASS="quote">bro its eaier thaan that just do what i did ... wait till its about -30deggrees outside and just bang the **** offwith a hammer </TD></TR></TABLE>
Here in CA it doesn't reach 30 degrees ofton
Old May 4, 2005 | 05:17 PM
Default Re: (Trooper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trooper &raquo;</TD></TR><TR><TD CLASS="quote">For the areas that are hard to reach, make a Dry ice slushie with some rubbing alchahol. That will work wondres by the firewall. </TD></TR></TABLE>
we had the entire dash, rebar, and wiring harness out before we started in on the sound crap, so it was still pretty easy.
And yea, i'm not sure the last time it was below freezing here in socal
Old May 4, 2005 | 05:18 PM
backdraft's Avatar
Or you can use a shoe horn and some 91 octane gas to get rid of that **** if you are really broke. It works really good. Your hand will hurt though. JDM_jon knows that ****.
Old May 5, 2005 | 09:03 AM
MackSpeed-616's Avatar
Default Re: (backdraft)
for those that dont want to mess with dry ice....
another fun way is to use an air hammer and just chiesel it off.
Old May 5, 2005 | 12:44 PM
Taco Sauce's Avatar
Dry ice works very good. We used it on my car and within about two and a half hours we had it all cleaned out.
-thomas
Old May 5, 2005 | 04:57 PM
Ls1 FD3s's Avatar
Default Re: (Taco Sauce)
man i seriously dont know why eveyone thinks this is such a pain in the *** and requires dry ice and or crazy misc stuff. Ive always used a hammer and chissel. Takes about 20mins to do a hatch and 30 for a coupe. Reason being a coupe takes longer is the thinner tar under the rear seat. In which sometime (rarely) i use a heat gun to get the crap up. Otherwise it always scrapes up in large chunks. I did a hatch once in 10 mins via hammer/chissel...
Old May 6, 2005 | 09:13 AM
MOPED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backdraft &raquo;</TD></TR><TR><TD CLASS="quote">Or you can use a shoe horn and some 91 octane gas to get rid of that **** if you are really broke. It works really good. Your hand will hurt though. JDM_jon knows that ****.</TD></TR></TABLE>
Old Apr 25, 2006 | 02:19 PM
thrty8street's Avatar
Default Re: (MOPED)
Old Apr 25, 2006 | 03:02 PM
2point2's Avatar
anyone try dry ice on the bottom of the car?
Old Apr 25, 2006 | 05:53 PM
boostedh22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Karterguy13 &raquo;</TD></TR><TR><TD CLASS="quote">
Here in CA it doesn't reach 30 degrees ofton</TD></TR></TABLE>
Right, let alone -30 degrees
Old Apr 25, 2006 | 06:21 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">welcome to 1999 prince</TD></TR></TABLE>
No doubt. Using dry ice and an air chisel owns every time.
Old Apr 25, 2006 | 08:09 PM
JL's Avatar
JL
Default Re: Small tip for removing sound deadning: DRY ICE!! (Slapshotnerd)
you can buy it at safeway up here in washington.. i used it on my sound deadening.. and could have re-used it in some dry ice bombs.
Old Apr 25, 2006 | 08:51 PM
miller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">welcome to 1999 </TD></TR></TABLE>
i was thinking the same thing, lol
Old Apr 26, 2006 | 08:33 AM
ringgold's Avatar
Default Re: (miller)
Last time I removed some deadning from any of my cars I used one of the small torches and a putty knife maybe a hammer I cant remember. it was not to hard to handle and I removed atleast 20lbs or more
Old Apr 26, 2006 | 09:04 AM
slvrstns2000's Avatar
or and even easier thing, just get the car acid dipped and it will take off everything!!!
Old Apr 26, 2006 | 09:36 AM
k20pinay's Avatar
Sounds like good times
Old Apr 26, 2006 | 01:10 PM
DSMu4ia's Avatar
You can get two types of dry ice.
Blocks, or crushed.
Crushed is just like crushed regular ice, and works much better.
Dry ice is definately the easiest/most preferred method.
CB
Dec 7, 2007 08:24 PM
Crispy
Welding / Fabrication
29
Mar 26, 2007 05:13 PM
Slowboy!
Aug 24, 2006 05:24 PM
crxpwr1
Jul 20, 2006 07:02 PM
VisualAutoMotoring
Aug 4, 2002 11:33 AM
