Mixing jic and -an fittings?....
Do any of you all know the difference in flare angle of -an and jic fittings? From what I gather -an is 36 degrees and jic are 37 degrees. Is this correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi »</TD></TR><TR><TD CLASS="quote">both 37*</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deepgreengsr »</TD></TR><TR><TD CLASS="quote">I Mix them all the time, Mostly when I don't have time to order Aluminum AN fittings I go to the boatyard down the street and but brass or steel JIC</TD></TR></TABLE>
Hydraulic shop is your friend too
On a different note, does such a conversion chart exist that converts AN sizes to JIC (or vice versa)?
Edit:
Did a lil research and found at http://www.fordmuscle.com/arch...tings/
Divide AN # by 16 to get inches
Modified by dennis at 10:43 AM 5/5/2005
Edit:
chad
Dec 2, 2003 04:13 PM
4drb18ek
19
Apr 30, 2003 06:31 PM
