PCV replacement
From: Why so you can pretend like youre interested, FL/OK
Pulled up the intake manifold thinking I had everything disconnected then looked at the bottom of the manifold to view a torn hose and a broken PCV on the top (D16Z6). I was searching on Hondaautomotiveparts.com but was unable to locate the PCV on either the intake manifold or fuel pipe diagram. Does anyone know where I can order this piece from either online or at a miscellaneous auto parts store. The Autozone here didn't have it, but maybe it was just this one if someone has gotten a replacement there before.
Any suggestions or help is appreciated. Thanks.
That's weird. Should be $2.99 at Kragen/Pepboys/Autozone or $20 at your honda dealer. Autozone should have had a shelf with a hundred PCV on display..........
I'm assuming youre talking about positive crankcase ventilation, not purge control valve or EVAP PCS or something
You wouldn't think there would be much difference but non oem PCV valves are shitty quality in comparison to OEM Honda ones. Ive had problems with PCV valves from pepboys and such and in the end, it would have been cheaper just to get one from satan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oh_crx »</TD></TR><TR><TD CLASS="quote">That's weird. Should be $2.99 at Kragen/Pepboys/Autozone or $20 at your honda dealer. Autozone should have had a shelf with a hundred PCV on display..........
I'm assuming youre talking about positive crankcase ventilation, not purge control valve or EVAP PCS or something</TD></TR></TABLE>
Sucks then because the nearest Honda dealership is 70 miles out.
Actually just got back from that way, another store can order one but Autozone here doesn't seem to carry it. So I guess I'll finally start the car back up tomorrow after it arrives.
AutokotoGSR
Oct 9, 2016 12:18 PM
SnailSlowDelSol
Feb 21, 2016 09:26 PM
seeeya04
Oct 2, 2005 11:14 PM
Louie_EM1
Mar 2, 2004 08:15 AM
