dpfi to mpfi problem please help
Old May 4, 2005 | 09:30 AM
Schaz's Avatar
Default dpfi to mpfi problem please help
okay well i rewired the dizzy and its all good now..but now when i try to start it it backfires....and wont start...would this be because of bad gas in it?? i cant check codes cuz the car needs to be running but...im thinkin its ignition timing? would this be correct...i turned the dizzy to be in the middle thinkin its like neutral timing if u can understand that and still nothing...any help would be appreciated thanks!!!
Old May 4, 2005 | 09:41 AM
Rywire's Avatar
Default Re: dpfi to mpfi problem please help (Schaz)
the car dosent need to run to check codes
Old May 4, 2005 | 09:43 AM
Schaz's Avatar
Default Re: dpfi to mpfi problem please help (droppedcrxsi)
is there a website with the codes on it??
Old May 4, 2005 | 09:49 AM
ED6Hatch's Avatar
If it is backfiring and all your wiring checks out, then it could be that the rotor on the dizzy is 180 degrees backward. just pop the dizzy out and pull the rotor off and rotate it 180 degrees. If is it backward, then it will try and fire on the exhaust stroke and will cause a backfire. But make sure your wiring is correct.
Old May 4, 2005 | 10:16 AM
Schaz's Avatar
Default Re: dpfi to mpfi problem please help (ED6Hatch)
can anyone tell me where to find ecu check codes for a pm6 ecu?
Old May 4, 2005 | 11:27 AM
Schaz's Avatar
^^^ bump
Old May 4, 2005 | 11:31 AM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schaz &raquo;</TD></TR><TR><TD CLASS="quote">can anyone tell me where to find ecu check codes for a pm6 ecu?</TD></TR></TABLE>
Well, the FAQ in this forum is a good place to start and in there you will find the codes listed. Here, let me do it for you:
https://honda-tech.com/zerothread?id=468260
BLU CIVIC
Sep 17, 2007 08:13 PM
pelotudo
Mar 6, 2003 08:23 AM
xci_ed6
Jan 23, 2003 12:40 AM
[626]95-GSR
Feb 14, 2002 06:11 PM
