NEW crx need wiring help
ook i have a 91 rex b16a y1 trans everyhting its all swapped and adn runs.. 1.Theres no vtec
didnt check the ecu to see if its hook up yet i no which pins to look at i just dont no wher the wires go?
2. tach doesnt work no speedo no gauge read outs basically, but when u put on a blinker the tach flash in Nsync(not the band)with d blinker 0-2 grand on over and over?wats crossed?
3. is im guessing a thermestat switch i have the fan hard wireed rti now b/c it wont kick on, any tell me where 2 find the old swithcd thanx...
didnt check the ecu to see if its hook up yet i no which pins to look at i just dont no wher the wires go?2. tach doesnt work no speedo no gauge read outs basically, but when u put on a blinker the tach flash in Nsync(not the band)with d blinker 0-2 grand on over and over?wats crossed?
what ecu? sounds like a obd-0 to obd-1 conversion gone horribly bad. first of all your vtec won't work until the tach and speedo work. i'd find out who did the swap and start with him.
what was the original car.
pr3/pw0 or something newer.
ignore the yellow.
those are the 4 wires you need to add for a b16a into an EF.
if you had DPFI and converted it to MPFI then you probably made mistakes.
search on here for MPFI swap to see what you did wrong.
ignore the yellow.
