Suspension & Brakes Theory, alignment, spring rates....
Quick question about camber any info is welcome
Old May 3, 2005 | 10:22 PM
magnumdad
Guest
Posts: n/a
Default Quick question about camber any info is welcome
can you use stock control arms with a kit to adjust camber...i don't know too much about how they work so i'm trying to gather some info...
Old May 4, 2005 | 08:27 AM
magnumdad
Guest
Posts: n/a
Default Re: Quick question about camber any info is welcome (magnumdad)
come on someone
Old May 4, 2005 | 08:34 AM
PIC Performance's Avatar
If you want to adjust the camber on the rears of you eg, you don't need to change the lower control arms at all. You would be changing your upper control arm, by either using the washer trick, or buying adjustable upper control arms. Search for "washer trick" on here or google.
Old May 4, 2005 | 08:48 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magnumdad &raquo;</TD></TR><TR><TD CLASS="quote">can you use stock control arms with a kit to adjust camber...i don't know too much about how they work so i'm trying to gather some info...</TD></TR></TABLE>
On the front, the camber kit replaces the upper A-arm and balljoint.
Chemi421
Suspension & Brakes
11
Aug 30, 2017 04:25 PM
jsum87
Mar 1, 2015 10:27 AM
ub3rn00ber
Jan 12, 2011 09:12 AM
97elitehonda
Suspension & Brakes
May 7, 2007 10:06 AM
stefanne3
Apr 11, 2007 06:57 PM
