Timing belt for mostly street driven caR?
Old May 3, 2005 | 09:23 PM
itr1244's Avatar
Default Timing belt for mostly street driven caR?
stock bottom end with cams/valve trains..
do i need those aftermarket (stronger?) belts? toda/greddy whatevers...
or
stick with oem kits? like this
http://www.prostreetonline.com...-hnd/
do i need the whole timing belt kit of just the belt alone?
did some search too but .. i probably suck with it.
thanks in advance
Old May 3, 2005 | 09:31 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: Timing belt for mostly street driven caR? (itr1244)
Unless you are running a really aggressive setup most people are probably going to tell you to use the stock timing belt tensioned properly.
Old May 3, 2005 | 09:33 PM
itr1244's Avatar
Default Re: Timing belt for mostly street driven caR? (ActiveAero)
right. i was thinking after martket but now i am more into oem kit...
oh yeah and i will be running golden eagle 440 cam gears
Old May 3, 2005 | 09:49 PM
b19coupe's Avatar
As stated, OEM belt properly tensioned. Depending on mileage, maybe do the drive belts and water pump too.
I am running an OEM belt with GE cam gears.
Old May 4, 2005 | 07:08 AM
Black R's Avatar
25 Year Member
PE/ toda belt can't hurt - especially if you have lumpy cams and stiffer valve springs.....
Old May 4, 2005 | 07:45 AM
Johnny Tran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">do i need the whole timing belt kit of just the belt alone?</TD></TR></TABLE>
I would throw a water pump on while i was at it...depending on mileage. :shrugg:
Old May 4, 2005 | 08:00 AM
white rocket's Avatar
Default Re: Timing belt for mostly street driven caR? (Johnny Tran)
I threw a PE belt on when I did cam gears basically just for something to do. It can't hurt. I opted to not do my water pump at that time because I only had about 60kms on the clock.
gosu08
Feb 11, 2010 05:01 PM
BLU CIVIC
10
Nov 12, 2009 07:02 PM
siRone
May 9, 2009 08:26 AM
turbociv
12
May 1, 2004 06:43 AM
allmotorhatch
Jun 8, 2003 05:57 AM
