AH!!! got an 88 ZC tranny with a 89-91 clutch an flywheel assembly!! what do i do???
ok, someone on here lied to me and told me they had a 89-91 jdm ZC trans, so i bought it. well, turns out they were lying/mistaken/lazy/worthless and it turns out its an 88. heres my situation, i have a 89-91 disk, pressure plate, release bearing and flywheel. what do i have to do to make this tranny work on my car? im BROKE and cant afford to buy a new clutch kit and flywheel. please tell me there is an easy way to kae this work. can i just buy a new disk? si there any way?? thanks for the help
Brett
Brett
i remember seeing on here, that if its the 90-91 flywheel, a clutch disc from an old prelude has that size and fits the 88's splines.
basically, i'm hoping to catch that person's eye, because i can't find the post, and don't remember what gen it's from
first off, do you have 89 clutch and flywheel or 90-91? they are different - 89 uses a 200mm clutch and 90-91 uses a 212mm clutch - the flywheels are not the same - the 90-91 has a larger diameter mounting bolt circle - if you have the 89 200mm clutch and flywheel, use the 88 CRX/Civic Si disc - if you have 90-91 212mm clutch and flywheel, use the 87 Prelude 2.0L disc
i actually have a 95 flywheel (same 212 mm) and a 90-91 disk and pressure plate.
holy ****, i cannot believe there is actually a cure for my situation. know anywhere u can get an 87 prelude disk for cheap? needs to be performance, i run 10psi of boost.
OR will a stock disk still hold up well with an upgraded pressure plate? cause if so, ill buy a cheap stock disk and keep my good exedy plessure plate.
Brett
Brett
new stock disc might work for a while, but it isn't going to last very long
even with the exedy pressure plate that i have? what if i swap the exedy springs over to the stock disk?
AND, who can i order just a clutch DISK from (performance disk) for the 87 predule si? anyone know?
Brett
Brett
impact_blu
Dec 30, 2005 04:07 PM
Ronin Panda
15
May 11, 2003 05:05 PM
