Del Sol or Civic DX
This might seem lame to you guys but i have a question of whether or not i should trade my 94 Civic DX with 118,000 on it for a Del Sol with about 230,000 on it.and could my intake be used on the Del Sol(its an AEM V2).
why do you want to trade it ? Do you want the Del Sol more than the Civic, if so, trade it. The intake might work, most Honda aftermarket parts are interchangeable, best bet is to try to put it on the Del Sol to see fitment, it takes less than 5 minutes to change it out. Good luck!
Well yeah I want the Del Sol but didn't know if it was worth trading my civic for.The reason I'm trading though is because I don't have the money to buy it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJcivic21 »</TD></TR><TR><TD CLASS="quote">Not sure on the trim level any distinctive features I should look for to tell the difference.</TD></TR></TABLE>depending if the car is stock and has never been modified..then look for these features-->if it has drum brakes in the rear, then you have an S ..if it has rear disc brakes and the gauge cluster begins redline at about 7200rpm or so, then you have an Si ...if the gauge cluster begins redline at 8200rpm, then you have the DOHC VTEC model(please check engine bay for the B16
) ..those might be some of the obvious things to look for..i would say test drive the car first to be sure that the mileage on the motor may not have started to actual ruin the motor etc..anyways good luck and hope you make the best choice that fits YOU ..not other people..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">del sol if its clean
I agree del sol are awsome cars
</TD></TR></TABLE>I agree del sol are awsome cars
people forgot some important stuff like check the trunk for water leakes also check the window seals for leaking. the sols are well known for leaking like a **** including mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocity »</TD></TR><TR><TD CLASS="quote">people forgot some important stuff like check the trunk for water leakes also check the window seals for leaking. the sols are well known for leaking like a **** including mine</TD></TR></TABLE>
Amen to that but they are relatively easy to fix.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJcivic21 »</TD></TR><TR><TD CLASS="quote">Yeah i heard the leaking problems are rare and simple to fix by getting new seals</TD></TR></TABLE>
by chance do you have an idea how much those seals are... your looking at 500+ for new seals. if i was aware of the leaking problem b4 i got my car i'd never have got it because of the inconvenience. also sols before 95 also didnt have trunk release so theres another feature you might be interested in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocity »</TD></TR><TR><TD CLASS="quote">by chance do you have an idea how much those seals are... your looking at 500+ for new seals. if i was aware of the leaking problem b4 i got my car i'd never have got it because of the inconvenience. also sols before 95 also didnt have trunk release so theres another feature you might be interested in.</TD></TR></TABLE>
You know my new seals were only 120ish.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curve »</TD></TR><TR><TD CLASS="quote">You know my new seals were only 120ish.</TD></TR></TABLE>
silicone is <$10 and works great for me, although you have to redo it every 6 months or so. door handles commonly break too. I hope you have money for a new engine soon, 200K + means it's probably not too heathly. Also, the v2 will fit if its the same motor. I don't think it'll line up with the b, but a hacksaw could probably fix that. Also remember that your dx is lighter, so the sol will be slower.
i got 233,000 on my cx hatch stock 1.5 motor.. i beat on it everyday harshly. got the b-series waiting 4 it. that del sol is proably fine. i would take a del sol over a hatch. the value of them r higher. and theres nothing like pickn up chicks with the top off in a jdm *** car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 »</TD></TR><TR><TD CLASS="quote">and theres nothing like pickn up chicks with the top off in a jdm *** car.
I don't see what about it is JDM, unless this particular car is. Either way, girls do have some unexplained attraction to del sols. I've never understood it, but it's a very real thing.
</TD></TR></TABLE>I don't see what about it is JDM, unless this particular car is. Either way, girls do have some unexplained attraction to del sols. I've never understood it, but it's a very real thing.
Really well thats a push in the right direction.Oh another thing i wondered was whether or not you get alot of wind noise like in a convertible.Also I'd probably do a engine swap within a few months so I don't think the mileage is a problem.
