throwing code 10 41 gsr eg
Old May 3, 2005 | 03:15 PM
redds's Avatar
Default throwing code 10 41 gsr eg
ok im throwing code 10 iat and 41 primary o2 sensor heater and before i was throwing these codes i threw a code for my iacv and i just got a valve adjustment done and i am running an obd1 p72 so my question is what to do to get rid of them THANKS in advance
Old May 3, 2005 | 03:17 PM
bogus_ek's Avatar
Default Re: throwing code 10 41 gsr eg (redds)
just got done with getting rid of my 41 code.... check all the wiring, make sure theres no wire exposed... pull connector from the main engine harness, and check the resistance between the two blk wires... helms sugges 15-40 ohm. i did all that, and it still didn't work, so i just replaced it with a working one. reset ecu and see what happens. that iat cel seems to go on and off whenever it wants to. i would check the wiring for that too.
Old May 3, 2005 | 03:49 PM
redds's Avatar
Default Re: throwing code 10 41 gsr eg (bogus_ek)
ok 41 code is gone now its 10 and 14 btw thanks bogus appreciate
blwn95civic
Sep 19, 2007 11:30 AM
Rukusmasta2
Mar 4, 2006 09:21 AM
fastfu
Feb 6, 2006 09:38 AM
EKtypeRhaTcH
Jan 13, 2005 04:53 AM
HYBRIDHATCH92
Aug 15, 2002 03:51 PM
