What rim size...and what tire size?
Old May 3, 2005 | 11:36 AM
unknown0001's Avatar
Default What rim size...and what tire size?
hey guys I am wondering what width are these rims????
They are the OZ/Fitipaldi 15" rims but the owner isn't sure of the width of the rim.
Any ideas of what it seems to be?
also...what would be the best tire size to run on these 15" rims?
I currently have 205/45/16 on now and I rub so I know I need 195's but what tire side wall height should I have?
Thanks
Modified by Mr.RHTuner at 12:53 PM 5/3/2005
Old May 4, 2005 | 07:34 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: What rim size...and what tire size? (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best tire size to run on these 15" rims?
I currently have 205/45/16 on now and I rub so I know I need 195's but what tire side wall height should I have?</TD></TR></TABLE>
195/55-15.
Old May 4, 2005 | 09:01 AM
ahs2m2's Avatar
195/55/15 is stock SI size
Old May 4, 2005 | 11:17 AM
Default Re: (ahs2m2)
any ideas on what the width of those rims may be?
Old May 4, 2005 | 11:26 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">any ideas on what the width of those rims may be?</TD></TR></TABLE>
You'll have to measure them.
Note that the measurement is based on where the tire bead sits, not the outer dimensions. For example, the stock wheel on the Integra Type R is a 15x6 wheel, but its outer dimensions are actually slightly more than 16" in diameter and slightly more than 7" in width.
Old May 4, 2005 | 12:03 PM
Default Re: (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You'll have to measure them.
Note that the measurement is based on where the tire bead sits, not the outer dimensions. For example, the stock wheel on the Integra Type R is a 15x6 wheel, but its outer dimensions are actually slightly more than 16" in diameter and slightly more than 7" in width.</TD></TR></TABLE>
Thanks...I read about that on the first link of this forum section
Old May 5, 2005 | 08:48 AM
EgRedSi's Avatar
195/50/15's if you do the drop right the body of your car will sit about three or four inches off the ground.
Old May 6, 2005 | 06:42 AM
darkjedi022's Avatar
Default Re: What rim size...and what tire size? (EgRedSi)
20/45/16..and you rub ??..is your car too low ....or is the offset off?
i have had that size and even bigger with no rub ....
Old May 16, 2005 | 09:04 PM
Default Re: What rim size...and what tire size? (darkjedi022)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkjedi022 &raquo;</TD></TR><TR><TD CLASS="quote">20/45/16..and you rub ??..is your car too low ....or is the offset off?
i have had that size and even bigger with no rub ....</TD></TR></TABLE>
I love being low
BXk24ek9
Apr 26, 2007 08:11 PM
JDMRice
Jun 18, 2005 07:27 AM
CivicEX96
Mar 16, 2005 05:09 PM
