radiator mounting diagram for 94-97 accord
Old May 3, 2005 | 10:22 AM
efficiencyJunkie's Avatar
Default radiator mounting diagram for 94-97 accord
Hey guys, do you have the diagram for the installation? I dont know where the radiator support mounts to the actual car and radiator. Help would be appreciated!
thanks
Old May 3, 2005 | 02:31 PM
z168's Avatar
Default Re: radiator mounting diagram for 94-97 accord (carbnjunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbnjunkie &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, do you have the diagram for the installation? I dont know where the radiator support mounts to the actual car and radiator. Help would be appreciated!
diagram for installation? no need for a diagram. remove the 2 brackets on the top, remove the hoses from the block. pull of the fans and pull the radiator out.
oh, of course you drain it first. check your owners manual to know the how-to to remove air from the system when you refill it with coolant
Old May 3, 2005 | 03:16 PM
Default Re: radiator mounting diagram for 94-97 accord (z168)
Cool, thanks man.
Do the fans bolt on as well? Also, I have to take of the plastic shield on the bottom of the car as well right? (to take of the bottom hose)
Old May 5, 2005 | 07:51 AM
z168's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbnjunkie &raquo;</TD></TR><TR><TD CLASS="quote">Cool, thanks man.
Do the fans bolt on as well? Also, I have to take of the plastic shield on the bottom of the car as well right? (to take of the bottom hose)</TD></TR></TABLE>
Yep the fans bolt on as well. The wiring of the fans are a bit tricky to remove but manageable. you dont need to remove the plastic bottom. to take out the hose, remove the clamp where the hose attaches to the block. and just carefully yank it out together with the radiator
Old May 5, 2005 | 11:42 AM
EX-JAY's Avatar
http://www.hondaautomotivepart...ND%29
Hey, this link will show you what parts to remove and how the radiator is held in place. Hope it helps.
Old May 5, 2005 | 01:34 PM
Default Re: radiator mounting diagram for 94-97 accord (EX-JAY)
Right on. Google is your friend! thanks guys
Rawr123
May 21, 2006 12:55 AM
BrokenRex
Oct 27, 2005 12:03 PM
vettman
Aug 5, 2005 06:07 AM
