JDM front bumper cover removal write up?
Old May 3, 2005 | 09:59 AM
AlxSiR7's Avatar
Default JDM front bumper cover removal write up?
i gotta take mine off so i can get it resprayed after a low mph collision.. any tips or write-ups??
Old May 3, 2005 | 12:35 PM
njandrewg's Avatar
Default Re: JDM front bumper cover removal write up? (AlxSiR7)
probably have 2 bolts holding it on each side, and then a bunch of clips inside the engine bay. That seems to be the general idea wiht front bumpers being mounted.
Old May 3, 2005 | 01:47 PM
Trance minister's Avatar
Default Re: JDM front bumper cover removal write up? (njandrewg)
Yeah, it's pretty basic with those bumpers. Don't overforce anything, it should all come off fairly easy. But, there's a bunch of plastic push rivets under neath that hold the bottom of the bumper up, there's 2 screw's on each end that screw into the botoms of the fenders to hold the corners up, There's probably some screws holding your splash guards in place that need to come off (not on mine), and the whole top part of the bumper is just pressed into these little locking tabs that hold it in place. They should pull right out with little force.
You might find it easier to remove the grill (actually I think you have to, I can't picture it in my head) to get the bumper off. But the grill just has 2 screws that screw into the headlight assembly on top, and 3 small clips that clip into the bumper support . Just press the tangs and they will pop out. They can be kind of a pain and the center of the clips might come out on you, but they just press back in. Good luck
deeweezy187
Aug 12, 2007 12:54 AM
racerxfactor
Mar 12, 2007 05:08 AM
AGB5901
15
Nov 24, 2003 06:31 PM
slowone
Jun 26, 2003 02:09 PM
CHRIS 1.8
12
Apr 27, 2003 07:43 PM
