What DOT skinny is everyone using ...
Old May 3, 2005 | 04:28 AM
Aggressive Racing's Avatar
Default What DOT skinny is everyone using ...
Old May 3, 2005 | 04:51 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: What DOT skinny is everyone using ... (aggressivemotorsports)
what else, M&H.
Old May 3, 2005 | 07:13 AM
anothaRRR's Avatar
Default Re: What DOT skinny is everyone using ... (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">what else, M&H. </TD></TR></TABLE>
Same here, M&H 24x3.6
Modified by anothaRRR at 10:26 PM 5/4/2005
Old May 3, 2005 | 07:36 AM
Pro-Am 1934's Avatar
Default Re: What DOT skinny is everyone using ... (anothaRRR)
MT: 15x4x22
Jason
Old May 3, 2005 | 09:16 AM
ranta18's Avatar
Default Re: What DOT skinny is everyone using ... (Pro-Am 1934)
How much are they? I've heard of people running front motorcyle tires that are rated for higher speeds too.
Old May 3, 2005 | 11:10 AM
T4eg's Avatar
Default Re: What DOT skinny is everyone using ... (ranta18)
24 3.7 mh's.
chris
Old May 3, 2005 | 01:37 PM
SlicksMH's Avatar
Default Re: What DOT skinny is everyone using ... (BlueHatch00)
M&H 3.5/22-15
M&H 3.6/24-15
John@M&H-Hashims
Old May 3, 2005 | 02:46 PM
Aaron92SE's Avatar
Little tip, Metzeler's are the lightest! Just pay attention to the load rating and you should be fine. They are DOT approved and there is nothing in the NHRA rule book that says you can't use them. It is just up to the track to enforce anything they think is considered "unsafe". This is my setup... 11lb 1994 RX7 16x4 wheels with 9lb Metzeler tires.
Old May 3, 2005 | 03:17 PM
project dc2's Avatar
Default Re: What DOT skinny is everyone using ... (SlicksMH)
wheres a good palce to buy bogart skinnies ? whats the prices on them ?
Old May 3, 2005 | 04:11 PM
h22 civic's Avatar
Default Re: What DOT skinny is everyone using ... (project dc2)
m&h
Old May 3, 2005 | 06:01 PM
ranta18's Avatar
Default Re: (Aaron92SE)
I've got some Honda Civic VX rims for now. They are hella light.
Old May 3, 2005 | 08:44 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">wheres a good palce to buy bogart skinnies ? whats the prices on them ? </TD></TR></TABLE>
I got my skinnies through Will @ exospeed. Then gave John @ MH a call on the 24 3.6's
Chris
Old May 3, 2005 | 09:51 PM
V-SPEC 1's Avatar
which one most of this size skinnies you guys use for 600+whp. 15x3.5x22 or the 24's. Thanks.
Old May 3, 2005 | 09:54 PM
SFWD 1934's Avatar
Default Re: (V-SPEC 1)
It kind of depends on every application. I.E: Chassis that it is in, suspension, size of front drive tires, amount of rake that you are looking for. As far as me, I run the 15x4x22 Mickey Thompson.
Jason
Old May 3, 2005 | 10:02 PM
V-SPEC 1's Avatar
Default Re: (SFWD 1934)
Ok thanks. I may try the 22's first.
Old May 3, 2005 | 10:05 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlicksMH &raquo;</TD></TR><TR><TD CLASS="quote">
M&H 3.6/24-15
Old May 4, 2005 | 11:38 AM
msmotorsports's Avatar
I'm running the M&H 22x3.5x15. BTW, I have a set of like new(only 5 passes) MT 24x4.5x15 I'm selling. Heres the link https://honda-tech.com/zerothread?id=1118477.
Old May 4, 2005 | 11:46 AM
paulzy's Avatar
I know these skinnies will mount to a VX wheel, but do you guys think it will be safe to run up 130mph traps with them?
John???
Aaron92SE, what's teh speed rating for those Mtezeler's?
Old May 4, 2005 | 01:30 PM
SlicksMH's Avatar
Default Re: (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">I know these skinnies will mount to a VX wheel, but do you guys think it will be safe to run up 130mph traps with them?
John???
Aaron92SE, what's teh speed rating for those Mtezeler's?</TD></TR></TABLE>
Hi paul vang; Up to 300 MPH.
John@M&H-Hashims
Old May 4, 2005 | 01:55 PM
paulzy's Avatar
Default Re: (SlicksMH)
John@M&H-Hashims </TD></TR></TABLE>
thanks, I should reword my question. Are they safe mounting onto a 4.5" wide rim? I think VX wheels are 4.5"
Old May 4, 2005 | 02:03 PM
SlicksMH's Avatar
thanks, I should reword my question. Are they safe mounting onto a 4.5" wide rim? I think VX wheels are 4.5"</TD></TR></TABLE>
Hi paul vang; Yes no problem.
John@M&H-Hashims
Old May 4, 2005 | 02:17 PM
Ram Air IV's Avatar
Skinny? I run Fattys...
245 60's daily.
M/T 26 x 10 x 15 if I wanna have some fun.
Old May 4, 2005 | 02:52 PM
Aaron92SE's Avatar
The speed rating on the Metzelers is V (up to 149 mph). The load rating is 550lbs. Best of all, it's a 9 lb tire on an 11lb rim.
__oversea
Honda Motorcycles
18
Apr 29, 2006 01:57 PM
integrated civic
Aug 24, 2003 08:39 PM
superteg_21
Jul 13, 2003 12:47 PM
MyDragCar
Jun 22, 2003 10:55 PM
Niemi
Apr 13, 2003 01:22 AM
