Sony 7 Inch wide screen receiver Sony 6 disc changer DC to AC Power Inverter
Testing the waters here ....... Everything works fine. I'm only selling these goods because I'm selling my Civic and I don't want a fold out coming out of my DC Integra console. Plus I could use the funds towards a swap
The changer is 6 months used and the receiver is a year and a half used. I only used the fold out at shows and I only do like 2-3 shows a year.
The receiver is part number #XAV7W and the changer is #cdx-T69. Here are some specs and pics. MAKE ME AN OFFER I CAN'T REFUSE
Sony In Dash Audio/Video Receiver - XAV7W/ Motorized 7 Video Monitor/ TFT Active Matrix Display/ Maximum Power Output (Watts): 45 x 4/ 16:9 Aspect Ratio/ Front/Rear Preamp Output/ AM/FM Tuner/ XM Satellite Radio Ready/Remote Control
In-dash media center and receiver
Optional DVX100 or DVX11A can be connected for viewing of DVDs
RDS radio with FM/AM/LW/SW
Flip out Colour 16:9 7" LC display
PAL, NTSC monitor
Control function for optional CD/MD autochanger
4x 45 watts max output
Dynamic soundstage organiser (DSO 2)
Separate bass and treble controls
EQ7 (7 band equalizer)
Pre-amp outputs Front and rear (Switchable high pass filter)
Sub output/switchable low pass filter
Sub volume control
Audio/video input (RCA) x2
Audio/video output (RCA) x1
Front panel segment display
Red key illumination
Safety commander interface 3.5mm jack
Sensor for Infra-red commander
Security code anti theft
Integrated clock 24h
Telephone attenuator
Installation angle plus or minus 15 degrees
Dimensions 178x50x186.2 (WxHxD mm)
Sony 6 Disc changer;
6-disc playback
will display the disc name from a CD-Text CD on compatible Sony receiver
0° to 90° mounting
will play CD-Rs or CD-RWs recorded on CD recorder or computer CD "burner"
frequency response 10-20,000 Hz
CD signal-to-noise ratio 93 dB
17-1/2' connection cable included
dimensions: 9-7/16"W x 2-1/2"H x 6-3/4"D
PICS;
Modified by iGntSegRa at 1:22 PM 5/3/2005
The changer is 6 months used and the receiver is a year and a half used. I only used the fold out at shows and I only do like 2-3 shows a year. The receiver is part number #XAV7W and the changer is #cdx-T69. Here are some specs and pics. MAKE ME AN OFFER I CAN'T REFUSE
PAL, NTSC monitor
Sub volume control
6-disc playback
0° to 90° mounting
PICS;
I dunno about this, Tim's a big guy and might beat you up for your money b4 you get it
jk
Bump for a good guy
jk
Bump for a good guy
brooksto
Audio / Security / Video
Nov 24, 2006 05:09 PM
