HP w/ stock B20?
What kind of horsepower could I expect to get by swapping in a stock b20 into a 2nd gen crx? Is it much below what I would get with a CRVTEC? And, I am kind of new to this, so how much turbo would the B20 be able to handle, could it handle 10 psi?
Thank you all
Ju$+iN
Thank you all
Ju$+iN
heh, the hp goes with the motor (more or less) so it would be about the same. since you may be using a different fuel pump and different size exhaust tubing, among many other small details, you MIGHT see a difference. but for the most part its the same. now crvtec is a tough one to call, you could see anywhere from 170 whp to well over 200. as far as boost, i have no idea, never been one to mess with that stuff. but judging from what i've read 10 psi sounds like a little too much on a stock motor.
