Suspension & Brakes Theory, alignment, spring rates....
which suspension for dd/autoX H&R, Progress or Ground control (did my homework)
Old May 2, 2005 | 09:00 PM
coot_er's Avatar
Default which suspension for dd/autoX H&R, Progress or Ground control (did my homework)
well i actually made a post similar about a week ago but i did some research and learning and now i have i much better idea of what i want. i also went to my first autoX on sunday and after seeing one in person it is definately something i want to do. i have a 91 crx with a stock b16 for the most part it is a daily driver but like i said im hoping to start autoXing about once a month. so here are my choices:
SPRING RATE (F/R) DROP (F/R)
Progress B series springs 325/275 2.0/2.0
H&R sport 350/250 1.9/1.8
Ground control coilovers 400/300? .5-3.5
if i get the ground control they are a little more expensive so i was wondering if i rode lowered an inch for daily driving and then like two inches for AutoX if i would need a camber kit still. i figure with the lowering spring i will definately need a camber kit. remember im just a beginner with auto X so i probably don't need the BEST but i do want to find a decent balance of daily driving comfort and performance.
Old May 3, 2005 | 06:19 AM
Deathwish's Avatar
Personally I'd advise you to go all out your gonna pay just a little more and get a huge difference in performance. Eibach and Koni.
Old May 3, 2005 | 06:39 AM
fireant's Avatar
Default Re: (Deathwish)
GC & Konis, without a doubt. Call Chris Shenefield at redshiftmotorsports.com, hell give you the whole package for $850 shipped.
Old May 3, 2005 | 06:58 AM
coot_er's Avatar
Default Re: (fireant)
would i need a camber kit with the GC and konis?
Old May 3, 2005 | 07:14 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">GC & Konis, without a doubt. Call Chris Shenefield at redshiftmotorsports.com, hell give you the whole package for $850 shipped.</TD></TR></TABLE>
I regret not doing this in the first place everytime I autocross.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">would i need a camber kit with the GC and konis?</TD></TR></TABLE>
Depends how low you go. Drop about 2" or less, get an alingment to set the toe to 0* and you'll be fine without one. I actually need one to dial in more camber in the front from scrubbing the outside of my tires, and I'm dropped 1.5".
Old May 3, 2005 | 07:39 AM
fireant's Avatar
Default Re: (AutoXer)
Its shocking but I bought both front and rear camber kits for dialing in more negative camber. Im at -2.3 up front and -1.5 in the rear. I'm very happy with it. Toe is zero(ish).
Old May 3, 2005 | 08:42 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">Its shocking but I bought both front and rear camber kits for dialing in more negative camber. Im at -2.3 up front and -1.5 in the rear. I'm very happy with it. Toe is zero(ish).</TD></TR></TABLE>
Hopefully I'll be able to do this next year. I'm saving up for the GC / Koni set up right now.
What kit are you using?
Old May 3, 2005 | 09:40 AM
fireant's Avatar
In the rear, I'm using the Ingalls threaded upper control arm with rubber bushings.
In the front, I'm using the Ingalls anchor bolt kit with poly bushings. They have two kits, one for +.5 to +3 (known as the silver kit because the block of steel its made from is silver), and another one for -.75 to +1.75 (known as the black kit - the block of steel is black). I have the black kit.
They make the black kit because sometimes a car needs negative camber added if it has hit a curb or something, and it is a good way to get some negative camber without having to drop too low for shock travel.
I got both mine at TireRack, and their prices are competitive.
Old May 3, 2005 | 06:52 PM
t0ekn3e's Avatar
i got gc and koni yellows
Old May 3, 2005 | 07:04 PM
hawjboi's Avatar
GC and Koni's all the way for me...
Eg2707
17
Jan 12, 2007 08:14 AM
coot_er
May 3, 2005 06:43 PM
phoenix down
31
Nov 10, 2003 02:32 PM
SleepinGSR
Mar 2, 2002 05:43 PM
