Buying block and head seperatly cheaper?
Old May 2, 2005 | 07:54 PM
seeeya04's Avatar
Default Buying block and head seperatly cheaper?
Well i will be maybe keeping my civic to do a swap and why is it iam finding it cheaper to buy the block and head seperatly.
because i found a ls tranny for $70.00 and the ls block for $90.00 and all i would need is the head which i could find with no problem..
so i guess what iam asking is do you all think it is easier to build a motor from the ls block like putting a b16 head on it..
or just buying a ls motor..
Old May 2, 2005 | 09:06 PM
s2k drifter's Avatar
Default Re: Buying block and head seperatly cheaper? (seeeya04)
Unless you know how to put an engine/trans together, I would suggest you buy a complete swap.
Old May 2, 2005 | 09:12 PM
O16581724 5 2 5's Avatar
"and all i would need is the head"
And intake manifold, and exhaust manifold, and throttle body, and...
Old May 2, 2005 | 09:23 PM
I'm not trying to burst you bubble, just giving you a heads up that its not easy as you say it is. I have a 98 gsr short block if your interested in buying
Old May 2, 2005 | 09:31 PM
nub.96ek's Avatar
Default Re: Buying block and head seperatly cheaper? (EK project hybrid)
It was for me... A LOT CHEAPER!!!
You just have to be patient and find deals... someone is ALLWAYS desperate for cash!!!
Old May 2, 2005 | 09:42 PM
Stoich EG2's Avatar
Default Re: Buying block and head seperatly cheaper? (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">It was for me... A LOT CHEAPER!!!
You just have to be patient and find deals... someone is ALLWAYS desperate for cash!!!</TD></TR></TABLE>
that is so fuggen true..
Old May 3, 2005 | 07:04 AM
seeeya04's Avatar
Default Re: Buying block and head seperatly cheaper? (Advan06)
So should i be buying my block and head and ect seperate since i have found deasl on all..
Old May 3, 2005 | 07:58 AM
doughboy_88's Avatar
i htink what it really comes down to is how comfortable you are with the purchase & assembly of the entire engine in parts. if you know what you're doing, you can save lots of money.
Old May 3, 2005 | 02:24 PM
seeeya04's Avatar
Default Re: (doughboy_88)
Gotcha but hey with the ls motor swap can i keep my same wiring harness..
And what iam i soppose to do with me stock motor and tranny? i wont have any use for it at all.
Old May 3, 2005 | 02:29 PM
Bcuz's Avatar
Dude just buy EK's block, if you go ls/vtec, you gotta drill oil passages to compensate for vtec oil passages. Buy his block, save yourself the time and headache.
Old May 3, 2005 | 02:41 PM
Default Re: (seeeya04)
I think some of these questions your asking is pointless now and not worth anwering anymore. You have to do some type of research and figure out whats a good buy and what isnt. If your looking to get your self into a project and and have alot of time on your hands, you should buy parts peice by peice and put it together with new bolts, screws, gaskets etc.
Old May 3, 2005 | 02:52 PM
seeeya04's Avatar
Default Re: (EK project hybrid)
Yea ok ek hybrid .. thanks for all the help
Old May 3, 2005 | 06:11 PM
arielmalespin's Avatar
how much for the gsr shortblock?
Old May 3, 2005 | 09:19 PM
Default Re: Buying block and head seperatly cheaper? (arielmalespin)
I was going to rebuild my gsr short block for turbo but ended up getting a really good deal on a complete swap so now its for sale. This short block has the crackshaft intact, I removed the pistons/rods but it be will included except for the oil pan. This is legit a LEGIT block, I have the vin plate on it and also receipt. Taking offers
Old May 3, 2005 | 10:28 PM
Andres-eh2's Avatar
My brother pieced together his gsr swap. This is what we ended up looking at.
Buying a complete swap = +/- $3,000 motor only, no clutch or tune up parts and on top of that you have a motor with about 50k+ miles.
My bro Piecing it together = +/- $3,500 WITH skunk2 manifold, type-r pistons, new rings, bearings, arp rod bolts and headstuds, 6 puck clutch and flywheel, hondata etc. Best part 0,000 miles!!!
Old May 3, 2005 | 10:51 PM
Default Re: Buying block and head seperatly cheaper? (Andres-eh2)
Interesting, I picked up a front clip from a shop which included engine, trans, ecu, mounts, axels, shift linkage, spindles, lower control arms, cross member, sway bar,
ac compressor, power steering pump and bottle, and a gsr harness. I forgot to mention this is a 2001 usdm gsr swap with 30k miles when it was removed. All this for the very low price of 2800 and a few hours to install. I think i'll make some money back after selling some of this stuff. I rather wait on selling parts and making my money back slowly then slowy finding parts to put together and taking forever to drive an enjoy it. Just my opinion
88 turbo crx
Sep 16, 2004 10:09 AM
Cyphear
Sep 6, 2003 11:08 AM
Brian_92GSR
Aug 27, 2002 01:25 PM
