quick question on offset?
Old May 2, 2005 | 06:00 PM
classciv's Avatar
Default quick question on offset?
i am looking into buying a cheep set of rims to run in autox. i am a beginer so i dont want anything fancy. i found a set a 38 mm offset will work on my 88 crx right? i am pretty sure that is what stock rims are but i want to make sure. also does anyone here run sportmax and how do you like them
Old May 2, 2005 | 06:38 PM
classciv's Avatar
Default Re: quick question on offset? (classciv)
any info on this would be great
Old May 2, 2005 | 06:54 PM
XrcR6's Avatar
Actually stock 88-91 Si was 14x5 +45mm. But 38mm will fit, assuming you're talking about something in the 6-6.5" wide range and keep the tire to a 205.
Old May 2, 2005 | 07:15 PM
classciv's Avatar
Default Re: quick question on offset? (XrcR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">Actually stock 88-91 Si was 14x5 +45mm. But 38mm will fit, assuming you're talking about something in the 6-6.5" wide range and keep the tire to a 205.</TD></TR></TABLE>
oh yeah sorry i forgot to include all the info. 4x100 15x6.5 at 14lbs each, not to bad i guess,
HAS ANONE HERE EVER BOUGHT SPORTMAX?
Old May 2, 2005 | 08:13 PM
EJ2-Fluffy's Avatar
The Rota GT3 (Gab copies) are the ones you want =P
Old May 2, 2005 | 09:37 PM
ryan89crx's Avatar
just get some slips and be done with it
rexdout45
15
Jul 15, 2006 06:43 PM
InfamousLude
Jun 17, 2005 07:54 PM
DJ_CARY
Feb 1, 2005 03:28 PM
VTECLuDe96
Dec 15, 2004 08:04 AM
classciv
Mar 19, 2004 08:32 AM
