b18b1, b18a, b17a once and for all please....searched
my situation is this. my timing belt broke on a 94 LS a while back and my valves got bent. i found a perfect 92 LS and put it on my block. its been running like **** and i need to know if the 92 LS cams are the same as 94 LS cams. i know the head is the same. im thinking maybe the cams are different...causing my car to run like ****. only other thing i can think of is that my injectors are crapping out because ive been boosting on stock injectors.
To sum things up, i just wanna know if the cams are different or the same. thanx.
