burning oil but where?
Old May 2, 2005 | 04:01 PM
user 98292739's Avatar
Default burning oil but where?
damn it this is pissing me off...my d16a6 was burning oil ONLY after the car was warmed up and cruising with gas pedal not depressed in 5th gear. i checked compression it was 160 across the board...i thought it was my valves...so i did a mini me. The head is fully rebuilt z6 with 0 miles. put everything back on. I opted to use the A6 manifold and keep the z6 manifold off. Still now it burns oil when im in 5th gear cruising with gas not pressed down. My compression after teh swap is 200 psi. head is brand new...i cleaned out my PCV valve today and its as good as new it clicks nicely but still it burns oil....what the hell is going on? where is it im burning oil? the funny thing is yea im burning oil BUT i barely lose any oil.....someone HELP PLEASE!
Old May 2, 2005 | 04:19 PM
shivern's Avatar
Default Re: burning oil but where? (LoCoReX)
check to see if its leaking onto your exhaust somehow, it'll burn the oil fro mbeing so hot and make you think your burning oil out of the exhaust..... CLEVER LITTLE CAR.
Old May 2, 2005 | 04:22 PM
what do you mean? oh nah i know its from exhaust cause its like a HUGE tornado of blue smoke. only in 5th crusing..
Old May 2, 2005 | 04:30 PM
Mach69's Avatar
Default Re: (LoCoReX)
Blue smoke that is coming out of your exhaust while cruising means you have bad piston rings.
However, like shivern said, it can drip onto the exhaust, but if you know its coming out of the exhaust at the back, then it is a piston ring.
Old May 2, 2005 | 04:54 PM
damn it! wtf....how is my compression so damn high then?
Old May 2, 2005 | 05:03 PM
CRXDrew's Avatar
Piston rings... unless maybe the valve seals weren't replaced?
Old May 2, 2005 | 05:18 PM
Mach69's Avatar
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">Piston rings... unless maybe the valve seals weren't replaced?</TD></TR></TABLE>
Well its either valve seals or piston rings. Usually at idle when you have blue smoke coming out of your exhaust its the valve seals, when you are cruising it is usually the piston rings.
Hey, if you don't believe me, wait for some more feedback. I don't know if compression shows worn out piston rings. SOMEONE clarify this.
Old May 2, 2005 | 05:35 PM
CRXDrew's Avatar
Compression will show worn rings. You will usually get a semi low reading and when you add a teaspoon of oil in the cyclinder and retest it the compression jumps up like 30psi.
This is a tell tale sign its rings.
Old May 2, 2005 | 05:38 PM
Trance minister's Avatar
Default Re: (Mach69)
What about valve guides? I too have had the same problem where under high vacuum situations (decelerating in gear), and as soon as I gave it some gas, there would be a nice blue cloud to choke people behind me. I replaced the valve seals and it still smoked. Compression was good as well.
I still have not determined the exact cause yet because I've pulled the head to have it rebuilt and get a valve job. I'm also replacing the rings while I've got the head off. It's got to solve the smoking problem, lol
Old May 2, 2005 | 07:26 PM
bagpipe goatee's Avatar
dumb question, but is there a ridge worn in the cylinder walls at all?
Old May 2, 2005 | 07:32 PM
ridge worn? when i did my mini me swap the cylinder walls were in perfect shape...i still saw some cross hatch SOME...motor had 173k
celltoolz
May 12, 2008 09:18 AM
jmv38
Mar 24, 2006 08:59 PM
SpeedMachine
Apr 29, 2005 12:27 AM
IggDawg
Nov 12, 2003 11:23 AM
CivicBoi
May 27, 2002 11:59 AM
