Axle is stuck!
Old May 2, 2005 | 03:34 PM
TurboEM1's Avatar
Default Axle is stuck!
Hey. I am doing a clutch in my 99si. I removed the axle nuts and the axle on the drivers side. On the passenger side i am having a lot of trouble. I got the axle nut off but i cant pull the brake assembly off the splines on the axle. I have tried everything. Is there a clip or something holding it in. I did the other side no problem so i know im not missing something on this side. It will not budge off the splines. Its been sitting in wd40 for days has been hammered on and i even custom made a bracket that just bent to pieces. I need some sort of strong tool that has power and will work. I have heard of using a pitman puller but hats not big enough to get around the rotor. PLEASE HELP ASAP! Thanks
Old May 2, 2005 | 03:44 PM
MiX's Avatar
MiX
there is a tool that using 2 lug nut studs and u bolt it on there and then use power tool or big breaker bar and its just screws into teh axle not really into it but towards and pushes it out.
Old May 2, 2005 | 03:48 PM
TurboEM1's Avatar
Default Re: (MiX)
thats the exact tool i tried to custom make but the metal bent bc it required so much force and it was not that thick. Do you know a name of that tool or any info. thats what i need. thanks
Old May 2, 2005 | 05:29 PM
TurboEM1's Avatar
Default Re: Axle is stuck! (TurboEM1)
ttt
Old May 2, 2005 | 05:39 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
PB Blaster!! That stuff is great. Spray it heavilly and let it soak overnight. Try and pull it off the next day. I would hold the knuckle out and hit the axle with a good size thick rubber mallet or something. You'll get it out.
Old May 2, 2005 | 05:54 PM
Lord Helmet's Avatar
Default Re: Axle is stuck! (JDM_Ej)
This is what I use to press the axle out. or at least break the "lock" the hub has on the axle. http://www.thetoolwarehouse.ne....html
Old May 2, 2005 | 05:59 PM
.Kevin.'s Avatar
i didnt take the pas side axle off i left it on and pushed it out of the way, just pop the axle out of the trans and move it to the side u should be fine
GarageAlchemist
Jul 27, 2006 03:04 PM
dynamo
13
Nov 14, 2005 08:22 PM
dextR
Sep 16, 2005 07:49 AM
EFM_ookie
16
Aug 14, 2005 09:27 PM
Feb 19, 2004 08:54 PM
