Switching from open to closed loop dumptube - How much will it affect my tune?
Old May 2, 2005 | 03:13 PM
Sprockets's Avatar
Default Switching from open to closed loop dumptube - How much will it affect my tune?
Like the title says. I'd like to do this, but I'm curious if I'll need another tune. I know I'll lose a few hp, but it's worth it to me. Does anyone know what will happen?
Old May 2, 2005 | 03:51 PM
s2kdre's Avatar
Default Re: Switching from open to closed loop dumptube - How much will it affect my tune? (B16A Grenade)
no tune needed, you'll just loose a couple hp.
Old May 2, 2005 | 03:56 PM
dustin's Avatar
Not needed. It will be the same.
I dynoed (low boost/HP ~ 240whp) and saw no difference in power between open and closed loop dump. I removed the dump tube while the car was on the dyno. (I actually gained ~1whp when closed loop.... This is probably because it took me about 10 mins to remove the dump tube and the car cooled down a bit).
If your engine is flowing enough air that the dumped exhaust + regular exhaust together are restricted in 3" exhaust (or whatever you are running) then you will lose power. Else it doesn't really make much of a difference at all.
Old May 2, 2005 | 04:41 PM
Sprockets's Avatar
Default Re: Switching from open to closed loop dumptube - How much will it affect my tune? (dustin)
That's good news. Thanks for the help, guys, I appreciate it!
Old May 2, 2005 | 07:31 PM
Si Shane's Avatar
Like he said, if anything you'll just lose some pwoer and richen up.
Old May 2, 2005 | 07:49 PM
PrecisionH23a's Avatar
Make sure to install the dump tube at the smallest angle possible to avoid a lot of turbulence. I would also try to place it at least 8-10 inches after the turbine flange on the dp.
Old May 3, 2005 | 09:18 AM
Sprockets's Avatar
Default Re: Switching from open to closed loop dumptube - How much will it affect my tune? (PrecisionH23a)
I will. Thanks, man.
HickamHatch
Dec 16, 2009 10:51 PM
hrdsktr1988
Honda Civic (2006 - 2015)
May 1, 2008 05:37 PM
blackeg
May 7, 2007 06:35 PM
HiProfile
Aug 6, 2006 07:47 AM
rollhard
Honda S2000
Jun 14, 2006 12:32 PM
