exhaust under gas tank??
Old May 2, 2005 | 02:39 PM
wrXtian's Avatar
Default exhaust under gas tank??
i've noticed a few guys are running their exhaust system as a straight pipe right under the gas tank and one bend (thus causing an angled exhaust). i was curious how safe is it to run the exhaust right under the fuel tank? most places i go they highly recommend against it.. is it just to save their *** so they won't get sued if some freak accident that has the odds of 1 and 1,000,000 happening? i'm assuming people are saying spontanious combustion can happen if the exhaust is under the fuel tank, but is that really realistic?
Old May 2, 2005 | 03:23 PM
686_ef's Avatar
Default Re: exhaust under gas tank?? (D16A6_HF)
ive had my exhuast under my tank for about 6 months never had any problems.
Old May 2, 2005 | 03:25 PM
TheCheeseWedge's Avatar
my exhaust has been under my tank for about a year or so, no problems other then my canister is a little floppy and hangs low
Old May 2, 2005 | 05:31 PM
TIRENECK's Avatar
Default Re: exhaust under gas tank?? (TheCheeseWedge)
im cool, gas tank could blow.
Old May 2, 2005 | 07:29 PM
bagpipe goatee's Avatar
if its hung right, i wouldn't be as worried about the tank blowing as i would be about it bottoming out and severely denting my nice new exhaust system.
Old May 2, 2005 | 08:04 PM
RCautoworks's Avatar
Default Re: exhaust under gas tank?? (TIRENECK)
I don't think an exhaust will ever cause a gas tank to explode
There are two things to worry about, heat and sparks. If you bottom out I could see the exhaust sparking but I don't sparking is an issue at all. I have used an angle grinder, and welded under my car and the sparks never blew me up. There is a ground coating on the gas tank that will prevent this.
As far as heat goes, well the exhaust really does not get to hot back there, I mean it does get hot but nothing to worry about. If Honda gas tanks were that sensitive then there would be a lot more Honda's exploding.
Old May 2, 2005 | 08:15 PM
EJ2-Fluffy's Avatar
Default Re: exhaust under gas tank?? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
As far as heat goes, well the exhaust really does not get to hot back there, I mean it does get hot but nothing to worry about. If Honda gas tanks were that sensitive then there would be a lot more Honda's exploding.</TD></TR></TABLE>
You never know. =P That's true though, I mean the coating under there was made for a purpose. I could see if you were going 150+ miles and u bottomed out and maybe there might be an explosion.
Old May 2, 2005 | 08:19 PM
Default Re: exhaust under gas tank?? (CRX-Fluffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">
You never know. =P That's true though, I mean the coating under there was made for a purpose. I could see if you were going 150+ miles and u bottomed out and maybe there might be an explosion. </TD></TR></TABLE>
There is a heat shield back there, if someone was really really worried, they could make a scatter shield.
But I mean, imagine how many people have owned a Honda and at one time driven over something hot, hot asphalt, hell even a small fire or fireworks is a good example. It will take a lot for it to exploded. And its the gasoline vapors that will do the damage, so your car would have to be leaking gas or have a hole some where. And then you would have to bottom out. Its not gonna happen.
Old May 3, 2005 | 01:15 PM
TIRENECK's Avatar
I still say KABOOOOOM
Old May 3, 2005 | 03:52 PM
Chase's Avatar
to the people who said they had their exhaust under the gastank, post some pics of it. I know theres an exhaust thread...but just for reference.
Old Sep 14, 2005 | 10:26 PM
RICE POLICE SIP's Avatar
Default Re: exhaust under gas tank?? (b16crxkid)
pics would be nice...
lilcaliplayany
May 3, 2016 11:38 PM
DA_DRE
Welding / Fabrication
27
Apr 4, 2008 03:08 PM
LaOstha
14
Oct 11, 2005 07:43 PM
AnToNy
36
Sep 15, 2005 07:44 PM
kholmes
10
Aug 30, 2004 06:47 PM
