INTEGRA MOTOR BUILD AND SWAP
Old May 2, 2005 | 01:44 PM
integraintegra's Avatar
Default INTEGRA MOTOR BUILD AND SWAP
ok i got an integra and i am going to do a swap...
what swap should i do B18 or B20??
pros and cons of both?
I also am going to be putting a turbo on... i am going to get a B18 or B20 and fully build it... stroker kit, sleeves, lower compression, valves springs retainers, cams, then turbo...
what would be the best motor to do this with... i am looking to spend around 10000 for this, and i can get either motor really cheap...
any ideas on what motor would handle turbo the best?
Old May 2, 2005 | 02:01 PM
FormulaGSR's Avatar
Default Re: INTEGRA MOTOR BUILD AND SWAP (integraintegra)
if you have 10,000 to spend i seriously suggest oyu spend some time researching here before you make any decisions or even ask any more questions.
Old May 2, 2005 | 02:10 PM
Yambor's Avatar
Default Re: INTEGRA MOTOR BUILD AND SWAP (FormulaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FormulaGSR &raquo;</TD></TR><TR><TD CLASS="quote">if you have 10,000 to spend i seriously suggest oyu spend some time researching here before you make any decisions or even ask any more questions.</TD></TR></TABLE>
Yep, Search, Research, search some more, confirm and search, then make a decision, there is so much info on b20 turbo, b18, ls/vtec, everything you wanted to know on the internet.
Old May 2, 2005 | 02:17 PM
numbnuts22715's Avatar
get like a dart block, or theres a nice engine they call the beast, check it out...
Old May 2, 2005 | 02:44 PM
Captian_Honda's Avatar
Default Re: (numbnuts22715)
Hey I've got a minute and can waste it on your question! Don't worry everyone asks a question like this when they first start out.
Get the B18C1, don't buy sleeves unless your planning 400+ HP, spend that money on a really, really, really, good tune&lt;----best place for your $$$. Buy a Garrett GT turbo --GT28RS if you have the dough-- and **** that B20.
Just keep lookin around and then you'll get a feel for it
Old May 2, 2005 | 02:49 PM
CompanyFlow's Avatar
Seriously, if you have that much money to spend, get a dart block and run 40 psi all day.
Old May 2, 2005 | 06:04 PM
Default Re: (CompanyFlow)
ok thanks guys ill look into it.... um im found a 2.0l stroker kit for the B18... any comments on that... i want it to still be reliable too... not too much psi probably 12-13 max
Old May 2, 2005 | 06:12 PM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (integraintegra)
All you need is a B18C1 with a good tune running 15psi daily and you'll be SET.
Old May 2, 2005 | 06:45 PM
Default Re: (litterbox)
are the B and C blocks the same?? could i just get a v-tec head?
projectcar929
Texas -OK -LA (Sales)
Sep 27, 2016 05:27 PM
92gsrsupercharged
Aug 23, 2007 11:55 AM
VTecCivic1505
Honda Civic (2001 - 2005)
24
Oct 6, 2006 01:01 PM
CompanyFlow
Mar 21, 2005 01:58 PM
guttedhatch
20
Jun 2, 2003 10:18 AM
