trunk?
Old May 2, 2005 | 01:00 PM
EJ8 GSR-T's Avatar
Default trunk?
Hey im lookin for pics or ideas about my system, i have two tens and and amp and i want to build something for my trunk to make it all look nice, pref no fiberglass but if you have something nice lemme see
Old May 2, 2005 | 05:53 PM
EJ8 GSR-T's Avatar
Default Re: trunk? (userdead626)
noone?
Old May 2, 2005 | 05:56 PM
Import_Dumbass's Avatar
take out the spare and custom **** so they fit there. a guy just put up a pic in the "what sub for" thread. looks decent.
Old May 2, 2005 | 06:11 PM
Vero's Avatar
ill get a shot of my two 10's when it stops raining. I built it so I could still use my trunk and keep the spare tire.
Old May 3, 2005 | 11:48 AM
EJ8 GSR-T's Avatar
Default Re: (Vero)
yeah see thats what i want, i want it to look nice but functionality would be nice also
Old May 3, 2005 | 12:43 PM
Vero's Avatar
I fiberglassed mine though, it is the only way maximize your space.
It wasnt hard though, took me about a week of off and on work.
Old May 3, 2005 | 05:51 PM
EJ8 GSR-T's Avatar
Default Re: (Vero)
did you have much previous expirence? yeah id love to see some shots when ya can.
Old May 3, 2005 | 06:23 PM
Vero's Avatar
Default Re: (userdead626)
none at all, I just did a little research on it from some write ups to get an idea. It also helped talking to a local stereo shop; they were able to give me some valuable info about size requirements, build specs and how to point the sub for best sound.
Tomorow should be a good day.
It is nice, I have my 5 channel 500 watt amp mounted on the back of the rear seat and 10" sub on each side of the trunk. I can fit my portfolio bag (36x24?) in trunk with no problems
Old May 3, 2005 | 06:32 PM
parasonic's Avatar
Default Re: (Vero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero &raquo;</TD></TR><TR><TD CLASS="quote">it is the only way maximize your space.</TD></TR></TABLE>No.
Old May 3, 2005 | 06:47 PM
Vero's Avatar
Default Re: (parasonic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parasonic &raquo;</TD></TR><TR><TD CLASS="quote">No.</TD></TR></TABLE>
very valid and informative response. show me how you made your speakerbox and maintainted virtually full trunk space and spare tire.
you could make an MDF box, but it wouldnt fit snugly into the corners like a glassed box does.
Old May 5, 2005 | 05:12 PM
parasonic's Avatar
Default Re: (Vero)
MDF box. Steel plate over the spare tire compartment. Custom welded brackets to hold the box in place. I have spent $200 so far on this project and will probably put another $100 or so in.
Old May 5, 2005 | 05:36 PM
Kyles ej1's Avatar
heres what i did when i had one 12. take out the spare tire and jack but keep the cover. i reinforced it with new wood underneath since it was bent from having all my baseball **** back there last yr. measure the size of the sub box and cut that into the spare tire cover thingy. the sub has to be facing up btw if u werent smart enough.
Old May 5, 2005 | 07:12 PM
EJ8 GSR-T's Avatar
Default Re: (93ejay1)
and how long have you had it like that? is your sub still sounding good?
Old May 6, 2005 | 12:51 PM
Vero's Avatar
took me long enough, but here are those pics of my two 10's
I did this with no prior experience, I just did some research and asked some shops.
From behind - you can see the amp mounted to the seat, and the subs in each corner by the tail lights. notice I have barely lost any trunk space.
this is the first one I did, as you can see, I didnt measuer one corner right, and I had to use some chims to make it hold correctly. One day I will make it match the car.
Here is the other side, I made sure not to have the same gap as before, this one fits great.
took me about a week of free time to do.
Old May 6, 2005 | 12:59 PM
Default Re: (Vero)
is that a 2 channel amp though or did you run the speakers together?
Old May 6, 2005 | 01:02 PM
deeksmooth's Avatar
Default Re: trunk? (Import_Dumbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Dumbass &raquo;</TD></TR><TR><TD CLASS="quote">take out the spare and custom **** so they fit there. a guy just put up a pic in the "what sub for" thread. looks decent.</TD></TR></TABLE>
that is i, custom box... dual chamber, sounds great... took it out though, just keeping 1 sub.
more pics http://deek.dyndns.org/d/system/index.htm
Old May 6, 2005 | 01:09 PM
Vero's Avatar
Default Re: (Import_Dumbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Dumbass &raquo;</TD></TR><TR><TD CLASS="quote">is that a 2 channel amp though or did you run the speakers together?</TD></TR></TABLE>
5 channel, runs the whole car.
Old May 6, 2005 | 01:31 PM
B00M3R's Avatar
Default Re: trunk?
Its not a speaker box (still working on that ) but here is my amp rack i made from scratch with fiberglass.
Here it is before it was finished so you can see it better.
It keeps the truck really clean and only takes up about 3 inches into the trunk.
when im done the trunk will have on 12" sub and should have plenty of room for whatever.
Modified by B00M3R at 11:08 PM 5/6/2005
Old May 6, 2005 | 06:01 PM
Vero's Avatar
yeah but no one can sit in your back seat now, and that looks like a nice theft magnet.
Dont get me wrong, it looks really good, the finish came out great! But I like how mine is all hidden, and I have my back seats if needed.
Old May 6, 2005 | 06:05 PM
EL Vap133's Avatar
Default Re: (Vero)
I think he took the pics like that so that you could be able to see it.
Old May 6, 2005 | 06:12 PM
Vero's Avatar
Default Re: (EL Vap133)
if you look where it mounts on the bottom, it lays ontop of the part where the rear seats mount to. The spot that allows them to pivot.
maybe I am just retarded, who knows.
Old May 7, 2005 | 10:38 AM
Default Re: (Vero)
well how did you run the amp to the two subs? did you i guess bridge the two for lack of better term?
Old May 7, 2005 | 01:16 PM
Vero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_Dumbass &raquo;</TD></TR><TR><TD CLASS="quote">well how did you run the amp to the two subs? did you i guess bridge the two for lack of better term?</TD></TR></TABLE>
simple, I made a Y harness that runs to the amp. I also made the harness using quick connect cables incase I need to take one or both out for any reason.
Most sub boxes use the same kind of Y type wire harness.
Old May 7, 2005 | 01:27 PM
jlacoy82's Avatar
71.192.16.183
Default Re: (Vero)
So did you run them in series or parallel? And whats the amp stable to? Not a bad job for your first time glassing though.
Old May 7, 2005 | 05:14 PM
Vero's Avatar
Default Re: (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">So did you run them in series or parallel? And whats the amp stable to? Not a bad job for your first time glassing though.</TD></TR></TABLE>
parallel, and I cant answer stability, I have had that amp for a few years and I never really crank it. I set it up a while ago.
