Tranny wont drop???
Old May 2, 2005 | 08:43 AM
Ben_si's Avatar
Default Tranny wont drop???
Im doing a clutch on my 00 si. Everythings unbolted but the tranny wont budge???? HELP
Old May 2, 2005 | 08:56 AM
sadangryboi's Avatar
u undo the flywheel cover bolts?
take off the intermediate shaft?
take off starter?
undid all tranny bolts for sure??
then pry that sucker open
Old May 2, 2005 | 08:59 AM
Ben_si's Avatar
Default Re: (sadangryboi)
i kicked it hammered it (with a hammer and a peice of wood mind you) I pryed it, I pulled it I tryed ******* everything. I cant find pic's to see if I have all the tranny bolts out so i cant tell. The ******* thing will not come off of the engine I cant figure it out
Old May 2, 2005 | 09:04 AM
SOHC4life 96's Avatar
Default Re: (Ben_si)
Did you take out the starter? Did you take off all the mounts that are connected to the tranny?
If you did, it should just slide back and then fall out.
Old May 2, 2005 | 09:06 AM
donut.'s Avatar
Default Re: (SOHC4life 96)
i had trouble with this also. i thought i didn't remove all the bolts but i did and i took a piece of wood and hammer and had at it. the dowel pins are whats probably still holding it on
Old May 2, 2005 | 09:10 AM
Ben_si's Avatar
Default Re: (donut.)
I think somthings still holding it on because I ******* wailed on it really hard and it didnt budge. Is there anyway I can get pictures so i can make sure I took out all the right tranny bolts.
Old May 2, 2005 | 09:19 AM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
Default Re: Tranny wont drop??? (Ben_si)
how many bolts have you taken off? you've removed the axle?
Old May 2, 2005 | 09:35 AM
al3e's Avatar
wiggle wiggle wiggle...
place a jack uner the oilkpan(peice of wood) and one under the tranny... and yeaah son!
Old May 2, 2005 | 10:05 AM
Bond's Avatar
Default Re: Tranny wont drop??? (al3e)
Just dropped mine yesterday. I forgot one bolt high on the backside and it held the tranny on there good. Once I removed it, just came out so nice and easy. It just slide out. I can almost garentee that you forgot a bolt. Just check on the backside.
Old May 2, 2005 | 10:07 AM
slowdx's Avatar
It would be hard to get pics of the bolts.
Just go all the way around it and make sure.
I dont see how its so hard to double triple and quadruple chekc for anything that could be holding it together. Probably less effort than making this thread.
Just keep checking and then get a really big screwdriver or prybar and slowly pry it off.
Old May 3, 2005 | 08:33 AM
Ben_si's Avatar
Default Re: (slowdx)
YES HAHAHAHA it was the starter bolts got those out and the bitch just slid rite out. Thanks who ever said it was the starter bolts
crxpwr1
Sep 23, 2006 12:53 PM
Ej1_coupe
May 17, 2005 08:37 PM
luti
Nov 29, 2004 11:52 AM
triggerX
Apr 24, 2004 12:03 AM
Unjockable
20
Nov 10, 2003 02:36 PM
