Alluminum Exhaust ???
Old May 2, 2005 | 04:26 AM
CRVRX's Avatar
Default Alluminum Exhaust ???
Has anyone tried this ? I don't think it would have a melting problem but I wonder if it would disapate heat too fast slowing the gases down.
Again , Please just the people that have experiance with this.
Thanks,,,
Old May 2, 2005 | 06:18 AM
civicross's Avatar
Default Re: Alluminum Exhaust ??? (CRVRX)
I think Geoff from full-race has an aluminum exhuaust on his civic.
Old May 2, 2005 | 07:45 AM
Ekasey's Avatar
Default Re: Alluminum Exhaust ??? (civicross)
Some people have talked about trying it.........
I would be really interested to see the results of course it would save weight, but i think there would be too many failures. On the other hand people have talked about usng some special coatings to prevent failures maybe i will try it on my RR car
Old May 2, 2005 | 08:01 AM
beepy's Avatar
Default Re: Alluminum Exhaust ??? (Casey@Burns)
From a Mech E. background....
The idea would work fine from the cat-back, for racing purposes at least. Using an aluminum exhaust on the street is a bad idea, though. Aluminum has no fatigue limit, so it will crack, eventually, no matter how perfect the welds or how well it was supported.
If an aluminum exhaust lasted 9 months in a daily driven car I would be surprised.
Old May 3, 2005 | 02:39 PM
99_GS-T's Avatar
It's probably not all that realistic anyway. The muffler makes up a good portion of the weight and finding an aluminum muffler might be hard. Normal mufflers will have corrosion issue where the aluminum tube will mount to it. If you are running in a class that doesn't require a muffler, the class probably doesn't require an exhaust at all. Although, you could find some perforated aluminum tube and build your own muffler. I did it with stainless steel and motorcycle muffler packing.
Either way, like Beepy said aluminum sucks in fatigue resistance, especially at elevated temperatures.
Old May 3, 2005 | 02:56 PM
CRVRX's Avatar
Default Re: (99_GS-T)
Thanks for the replys.
I am interested in a street application, I just wonder about long term use.
The piping is very heavey in 3" stainless , I would say it would save 20lbs or more.
I might try it anyway, I'll keep you updated .
Old May 3, 2005 | 03:11 PM
Ekasey's Avatar
Default Re: (CRVRX)
You can always try thin gage 321 stainless .035 quite expensive but it is made in 3" diameter
Old May 3, 2005 | 05:04 PM
Full-Race Geoff's Avatar
driving every day on it, no problems yet. Im a mechanical engineer also, and i feel that this is an acceptable exhaust for a properly built street race car. no problems yet. saves about 35 lbs for a 4"
Old May 4, 2005 | 09:03 PM
manekDC2.'s Avatar
Default Re: Alluminum Exhaust ??? (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">driving every day on it, no problems yet. Im a mechanical engineer also, and i feel that this is an acceptable exhaust for a properly built street race car. no problems yet. saves about 35 lbs for a 4"</TD></TR></TABLE>
yea Geoff i ment to ask you some questions about that exhuast.. i'll try to get a hold of you at the shop, but you car is just plain raw
Old May 5, 2005 | 07:44 PM
rjay8604's Avatar
Default Re: Alluminum Exhaust ??? (ManikGSR)
Wow, thats a pretty novel idea and someone is actually doing it. Keep this thread going.
Old May 5, 2005 | 08:44 PM
Rtype16's Avatar
Default Re: Alluminum Exhaust ??? (rjay8604)
Shouldn't be a problem at all we have been planning to do it to a few cars at the shop.
Old May 6, 2005 | 11:25 AM
nullassault's Avatar
whats wrong with titanium?
Old May 6, 2005 | 06:38 PM
PrecisionH23a's Avatar
Default Re: (nullassault)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nullassault &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong with titanium?</TD></TR></TABLE>
It's expensive as hell. The guys from GSC run a full 4" aluminum exhaust on their drag car... I was thinking about doing the same on my new EK drag car.
Old May 6, 2005 | 10:41 PM
chrisgvr4's Avatar
Default Re: (PrecisionH23a)
I'm running one on the gt42 GVR4 and am about to put a 3" through daily driver paces on my turbo Colt including an aluminum muffler I made. I will post pictures when it's done.
Old May 7, 2005 | 10:08 AM
beepy's Avatar
Default Re: (chrisgvr4)
I would be interested to see how the resonance of an aluminum muffler compares to a similar steel muffler.
Del Sol
Jun 27, 2005 01:41 AM
eymnewdc4
Feb 13, 2005 04:02 AM
03Si
Honda S2000
15
Dec 18, 2004 07:58 AM
Jared
Oct 4, 2003 10:15 PM
Triumphant
Mar 30, 2003 06:24 PM
