tranny problem. in gear but car does not move, mph goes up, tranny noise
Old May 1, 2005 | 10:20 PM
Ignitecivic's Avatar
Default tranny problem. in gear but car does not move, mph goes up, tranny noise
damnnn got a tranny problem today right when i got home too. car is b16a3 with stock clutch. rite when i got home, put it in first gear ccar doesnt move at all. it makes some nasty *** sound coming from the driver side. it sound like something is grinding or the clutch disk drop and its spinning.
problems are
1. tranny in gear, car not moving ( every damn gear)
2. crazie *** sound when in gear while releasing the clutch trying to get the car moving.
3. speedometer goes up when i try to get the car moving in gear at every gear.
can it be the axle that pop out alittle or the clutch is completely gone. i can shift into every gear but when i try to get the car moving it doesnt movem it just makes the sound. the tranny is new cuz every gear is smooth but just the clutch was worn when i bought the car.
any help would be great.
TIA
Old May 1, 2005 | 10:32 PM
SwapShopR's Avatar
No Sales Forums
Default Re: tranny problem. in gear but car does not move, mph goes up, tranny noise (Ignitecivic)
It is either an axle problem or you differential is busted. I would check the axles first.
Old May 1, 2005 | 10:45 PM
G U E C O's Avatar
Default Re: tranny problem. in gear but car does not move, mph goes up, tranny noise (SwapShopR)
check your axles maybe one of the axles or both might haev popped off while installing it.
did u jsut install this tranny? was it always on your car and this problem just happened?
Old May 2, 2005 | 04:51 AM
Lmgrcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapShopR &raquo;</TD></TR><TR><TD CLASS="quote">It is either an axle problem or you differential is busted. I would check the axles first.</TD></TR></TABLE> check these 2 things first worst case the tranny could be completly gone had it happen to a friends car. will the car roll if its in nuetral.
Old May 2, 2005 | 08:04 AM
Default Re: tranny problem. in gear but car does not move, mph goes up, tranny noise (Lmgrcivic)
the tranny came stock with the car. the axle was replace about 6 months ago so i will check on that.
can it be the clutch? if its the clutch i wont be able to go into gear rite.
Old May 2, 2005 | 08:50 AM
MonkeyMagic's Avatar
axle is either busted, or has come out of the trans.
btw, the snap rings on the inside of the axles are a consumed part, after you pull an axle out they are supposed to be replaced. chances are yours weren't, so just bend thema bit bigger with pliers... but make sure they aren't to big as to slip out of the groove in the axle
Old May 2, 2005 | 10:36 PM
Default Re: tranny problem. in gear but car does not move, mph goes up, tranny noise (MonkeyMagic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyMagic &raquo;</TD></TR><TR><TD CLASS="quote">axle is either busted, or has come out of the trans.
btw, the snap rings on the inside of the axles are a consumed part, after you pull an axle out they are supposed to be replaced. chances are yours weren't, so just bend thema bit bigger with pliers... but make sure they aren't to big as to slip out of the groove in the axle</TD></TR></TABLE>
yeah it was the axle guys. the damn shop installed it wrong or sumthing.
thanks for the tips. i was hoping it wasnt the differential.
Old May 3, 2005 | 09:02 AM
thisisntjared's Avatar
yea your fortunate, when the diff goes it really sucks. glad to hear its solved so quickly
Eric Charette
Transmission & Drivetrain
Mar 16, 2013 08:50 PM
leem23vtec
Oct 10, 2008 11:44 AM
payneth
Oct 4, 2005 06:17 AM
itr1244
Sep 15, 2002 08:57 AM
